Caliper Refurb
srichards
Re: Caliper Refurb
Post by srichards » Thu Oct 14, 2021 9:31 am
Puggie wrote:
Thu Oct 14, 2021 9:27 am
I've just checked my spare calipers and definitely 28 and 32. I can probably find my pistons this evening (in an ice cream tub in the garage somewhere) and measure up the height and seal gaps if you need.
Sent from my SM-G973F using Tapatalk
Thanks. That would be useful.
Puggie
Re: Caliper Refurb
Post by Puggie » Fri Oct 15, 2021 2:20 pm
Does this help?Image
srichards
Re: Caliper Refurb
Post by srichards » Fri Oct 15, 2021 2:52 pm
:thumbs: That's very helpful.
V!per
Re: Caliper Refurb
Post by V!per » Tue Oct 19, 2021 7:22 pm
I wonder if our friend from the poosey pipe could get couple of sets of those
steve2003rs6
Re: Caliper Refurb
Post by steve2003rs6 » Tue Oct 19, 2021 10:33 pm
Viper. Anything can be made.
Would need to know the material.
And cost of new in comparison to manufacturing cost to see if there is any benefit.
Sometimes it’s cheaper to buy off the shelf.
Also. Machine Shop can be very fussy making parts for anything to do with a braking system.
I recall a motor bike enthusiast calling round to have his bike discs skimmed.
Although we have done hundreds for cars.
The manager refused to do them for bikes.
Puggie
Re: Caliper Refurb
Post by Puggie » Wed Oct 20, 2021 12:24 am
They are barely magnetic and not that heavy, so I suspect stainless steel, the main body I believe is hollow (from the weight) and the top cap pressed on. The overall look is grey, I'd guess a ceramic coating of sorts (they dont look or feel like phenolic pistons from a motorbike caliper. I must say, my calipers were seized, I used an enerpak hand pump to get the pistons out and they cleaned up pretty well, certainly good enough to re-use IMHO. The regular chrome plated steel pistons in my Honda calipers look god awful in comparison despite being a similar age. The bleed nipples on these calipers were corroded in solid, I ended up drilling and helicoiling the caliper bodies, no amount of heat or abuse would shift them (tig welded nuts over them in the end and the nips sheared off at the calipers surface).
steve2003rs6
Re: Caliper Refurb
Post by steve2003rs6 » Wed Oct 20, 2021 8:43 am
My spare original calipers are in the garage at the moment. The bleed nipple threads in the caliper are knackered. Intend to have them repaired sometime in the near future.
Thought of helicoiling but unit 20 suggested another repair superior to helicoil.
In the meantime I had new phaeton 8 pot calipers installed at unit 20. Grizz recommended them.
Very impressed with them so repairing the originals has been put on hold at the moment.
srichards
Re: Caliper Refurb
Post by srichards » Wed Oct 20, 2021 9:35 am
The pistons will be available it's just which ones. Mine is booked in for next week so I'm going to try and make sure I find out exactly which ones are ordered.
steve2003rs6
Re: Caliper Refurb
Post by steve2003rs6 » Wed Oct 20, 2021 11:02 am
Hope all goes well for you suz.
And the price isn’t extortionate.
srichards
Re: Caliper Refurb
Post by srichards » Wed Oct 20, 2021 11:56 am
The after market ones seem to be about £10 a pop. They may be fine in which case I'll be no help at all :biggrin3:
Puggie
Re: Caliper Refurb
Post by Puggie » Wed Oct 20, 2021 2:57 pm
The only corrosion on any of mine was minor and above where the dust seal sits (you can see it on the picture I posted of the smaller piston). This corrosion was slight and cleaned off very easy with a little fine scotch disc in a dremel. I'd be surprised if you really need new pistons.
srichards
Re: Caliper Refurb
Post by srichards » Fri Oct 29, 2021 4:19 pm
Didn't need new pistons, oddly enough.
Piston part numbers will have to remain a mystery!
TechNick
Re: Caliper Refurb
Post by TechNick » Fri Oct 29, 2021 9:44 pm
On the aesthetics side, has anyone found a decent OEM substitute for the logo on the calipers? (I'm assuming you can't get them from the dealers anymore, if you ever could).
Lander91
Re: Caliper Refurb
Post by Lander91 » Sat Oct 30, 2021 7:14 am
Ive been searching and found this crew:
https://www.brakecaliperdecals.co.uk/Au ... ake-Decals
Option 5 would be close to standard, not sure if the black of the decal would match the black of the caliper, and if these could effectively cover the faded factory ones.
Worth a look as they're cheap enough.
I don't feel up $$helling out for a stenciled logo to be painted on.
TechNick
Re: Caliper Refurb
Post by TechNick » Sat Oct 30, 2021 5:18 pm
Thank you. Yeah, seen those before and think you're right - they're probably the best out there, currently.
As you say, for the price they'd be worth a punt Image
