Hi,
It seems my passenger side bottom speaker has blown, well sounds terrible. Can someone kindly tell me best place to get one and part number if possible. Obviously I haven't removed door panel yet, not sure how much of a pain that is?
Passenger door bottom speaker (sub woofer)
Re: Passenger door bottom speaker (sub woofer)
The door panel is not too bad to remove, the only annoying bit is the screw in the handle that is really deeply recessed and needs a long, thin extension. This video shows the process, the annoying screw is at about 2 minutes:
https://youtu.be/-bIrl2seUVQ
In terms of the part number you can get the parts catalogues at catcar.info I guess the part you want will be somewhere on http://www.catcar.info/audivw/?lang=en& ... AzNTM1NDQ4
The whole speaker/bass box assembly is 4F0035381D (I think). From what I recall from when having door cars off an A6 the speaker is held onto the box with 4 plastic welds instead of screws - I'd be inclined to remove the welds, find a replacement speaker (with luck there's be a Bose part number on the speaker) and then fix it to the box with small self-tappers.
Cheers for reply, will definitely be watching YouTubeBobBobson wrote: ↑Sat Oct 23, 2021 10:18 pmThe door panel is not too bad to remove, the only annoying bit is the screw in the handle that is really deeply recessed and needs a long, thin extension. This video shows the process, the annoying screw is at about 2 minutes:
Thanks for infoJim Haseltine wrote: ↑Sun Oct 24, 2021 10:20 amThe whole speaker/bass box assembly is 4F0035381D (I think). From what I recall from when having door cars off an A6 the speaker is held onto the box with 4 plastic welds instead of screws - I'd be inclined to remove the welds, find a replacement speaker (with luck there's be a Bose part number on the speaker) and then fix it to the box with small self-tappers.
Users browsing this forum: Google Adsense [Bot] and 50 guests
