Passenger door bottom speaker (sub woofer)
5.0 V10 50v biturbo - 571 bhp
Geedub
Post by Geedub » Sat Oct 23, 2021 4:49 pm
Hi,
It seems my passenger side bottom speaker has blown, well sounds terrible. Can someone kindly tell me best place to get one and part number if possible. Obviously I haven't removed door panel yet, not sure how much of a pain that is?
BobBobson
Re: Passenger door bottom speaker (sub woofer)
Post by BobBobson » Sat Oct 23, 2021 10:18 pm
The door panel is not too bad to remove, the only annoying bit is the screw in the handle that is really deeply recessed and needs a long, thin extension. This video shows the process, the annoying screw is at about 2 minutes:
https://youtu.be/-bIrl2seUVQ
In terms of the part number you can get the parts catalogues at catcar.info I guess the part you want will be somewhere on http://www.catcar.info/audivw/?lang=en& ... AzNTM1NDQ4
Jim Haseltine
Post by Jim Haseltine » Sun Oct 24, 2021 10:20 am
The whole speaker/bass box assembly is 4F0035381D (I think). From what I recall from when having door cars off an A6 the speaker is held onto the box with 4 plastic welds instead of screws - I'd be inclined to remove the welds, find a replacement speaker (with luck there's be a Bose part number on the speaker) and then fix it to the box with small self-tappers.
Geedub
Post by Geedub » Sun Oct 24, 2021 10:31 am
Cheers for reply, will definitely be watching YouTube
Geedub
Thanks for info 👍
