no start after engine pull
airtite
Post by airtite » Thu Oct 21, 2021 11:52 am
Hi Guys
OK so motor back in and everything connected, front bumper and lights still off so I can test fire and make sure no leaks... new oil, oil filter, battery charged, motors turns at the crank so its not locked up.... key turns, lights on dash normal but the starter doesnt even swing.... VCDS showing no faults on engine or gearbox module?
Any ideas where to look?
Jayjay101
Re: no start after engine pull
Post by Jayjay101 » Thu Oct 21, 2021 11:55 am
airtite wrote:Hi Guys
I’d start with the starter!! Got to have a lose wire if it’s not getting any power-fuse? That’s the worse part of a engine pull for me getting the starter wiring off and on!!
airtite
Post by airtite » Thu Oct 21, 2021 12:04 pm
i didnt touch any of the wiring at the starter, I disconnected from the mega fuses in the firewall under the expansion tank and pulled the harness through the firewall still connected to the motor.
Puggie
Post by Puggie » Thu Oct 21, 2021 12:15 pm
Check your engine earth to chassis. Multimeter between the block and chassis on volts. If you see 10-14volts DC when you 'crank' the engine it's your engine to chassis earth. That was my cockup when I had the engine out. I now have a massive ground cable from sub frame mounting to where the aircon or pas pump bolts to the block.
Sent from my SM-G973F using Tapatalk
airtite
Post by airtite » Thu Oct 21, 2021 12:53 pm
ok so my 200amp mega fuse is blown.... the question is why? Can anyone confirm that my earth and alternator wires are correct here?
airtite
Post by airtite » Thu Oct 21, 2021 1:27 pm
so in my picture above, can anyone tell if its the wire sheathed cable thats meant to go to the alternator or is that the earth?
airtite
Post by airtite » Thu Oct 21, 2021 2:58 pm
car starts, I am an idiot... I had swapped the earth and positive at the alternator... new 200amp fuse fixed wiring and car starts.
Users browsing this forum: skyegtb and 69 guests
