Warped discs and pads - advice required
crapbag
Re: Warped discs and pads - advice required
Post by crapbag » Thu Sep 02, 2021 5:58 pm
Sorry to hear your woes. I remember reading that drill holes get blocked up with deposits and they can be the culprit of vibrations under braking. By drilling out the holes this cleaning them out stops the vibrations. It’s got to be worth a try for a free bar time taken.
Please let us know if you try it. And what the result is.
Craig.
SchrickRS6
Post by SchrickRS6 » Mon Sep 06, 2021 1:37 pm
Apparently the brake caliper brackets and bell housing were out of whack - just had the new pads on (rear) and it feels silky smooth, at lower speeds but at 70kmh there was ever so slight vibration - which I assume is the old brake pad residue still on the discs?
J
Current :Audi RS6 2016 PE Ascari Blue
Previous: BMW's, Mainly M5's E34-F10 and an Alpina B8, with a few Cozzies thrown in.
Royclarke
Post by Royclarke » Mon Sep 06, 2021 10:47 pm
I’ve had a rs6 c7 for 2 years now and I to got the brake judder really bad,in my case and you won’t believe it it was all down to the wheel cleaner I was using,turned the disks red with the active stuff in it as I was spraying the wheels,messing up the pad transfer and making them judder bad,once bedded back in abit they were fine,I’ve had the disks glowing hot and have never warped them,brake fade yes but once cooled back to normal
HDPete
Post by HDPete » Mon May 22, 2023 9:10 am
Thanks to this thread, I am trying new hubs, brake hoses and also get the callipers stripped and reconditioned. I’ve had two sets of discs and pads now and the vibration comes back after around 6,000 miles. Local garage has spotted one of the pistons is sticking so it’s an ideal opportunity to strip it all bare and hopefully avoid the cost of another set of discs.
HDPete
Post by HDPete » Mon May 22, 2023 9:12 am
Hubs were around £150 each from Jayar
Hoses £60 from Audi
Calliper rebuild £150 each (7 day turnaround @ Bigg Red)
HDPete
Post by HDPete » Mon Jun 26, 2023 10:05 am
Just a quick update after the following:
New brake hoses (£60 @ Audi)
Calliper rebuild x2 (£250 @ Bigg Red / 3 day turnaround)
New Hubs & Bearings (£340 @ Jayar)
Labour £340 @ VAS Works in Poole
The aggressive judder has definitely gone. There’s still a slight vibration which I’m assuming is the previous uneven pad wear and giving it a few hundred miles to see if it goes.
It would certainly seem that the hubs were the original cause, so my advice would be to change those before Shelling out on discs.
Users browsing this forum: Google Adsense [Bot] and 46 guests
