Oil leak continues
steve2003rs6
Oil leak continues
Post by steve2003rs6 » Wed Aug 11, 2021 12:48 pm
Having sorted the two oil leaks from the transfer box and turbo oil drain pipe.
Still have small oil drips on the drive to the front near side.
The under tray remains clean and dry.
Looks like I have a very slight leak from the cam cover gaskets to the front corners on both sides.
Was going to get these done previously but parts did not arrive.
Hopefully get them sorted soon if we can obtain them.
Weiß-sechs
Re: Oil leak continues
Post by Weiß-sechs » Wed Aug 11, 2021 1:41 pm
Bummer. Mine are slightly damp around the cam covers but hasn't progressed to leaving drips on the drive...yet.
steve2003rs6
Post by steve2003rs6 » Wed Aug 11, 2021 2:01 pm
The cam covers is the only place where I can see any form of a leak.
I really do hope replacing the gaskets cures the problem.
The drips on the new drive has been evident for some time now and it needs to be resolved.
Just called Audi.
£126 for both gaskets.
I am told the part number is
077198025A.
Post by Shoppinit » Wed Aug 11, 2021 2:48 pm
Yeah, but the problem is changing them. One is an engine-out job, in theory at least.
steve2003rs6
Post by steve2003rs6 » Wed Aug 11, 2021 4:00 pm
Hi Ben. Just been watching videos on how to.
They can be done with engine in situ I am led to believe.
There is a pipe that needs to be manoeuvred out of the way. Damage the pipe and it’s engine out !
However it’s not a job I would attempt.
I will Leave it to the experts in Neston.
The cam cover leak on mine isn’t bad really. It looks a bit wet at the front corners. Just cannot see anywhere else where the oil drips can be coming from.
The transfer box seal is now sound. As is the turbo oil drain pipe - many thanks to unit 20.
I guess it’s find and fix until there are no more drips on the drive.
Had a bit of a smile though. The local mechanic asked if I had a private number plate on.
Didn’t believe that it was a 18 yo car.
Makes all the effort worthwhile.
However when I recently had the paintwork done. I really regret not having the front end redone.
Came across a really old thread on here. Suggested re torque of cam cover holding down bolts.
Not sure on that one. But it might be worth a try.
Lander91
Post by Lander91 » Thu Aug 12, 2021 3:50 am
Its really straight forward, no risk to the coolant pipe unless you sit there wiggling it back & forward. Id recommend getting inspection mirror (the small telescopic kind) just to make sure its the covers.
Lastly the one thing to look out for if you're doing it yourself, or making the talking to the technician is to keep an eye on the cover bolts in the centre (2 each side) as well as the spark plug holes. With mine there was thin slivers of corrosion sitting loose and ready to drop onto the cams etc. Blow/vacuum these holes out when the bolts are removed - before taking the cover off.
steve2003rs6
Post by steve2003rs6 » Thu Aug 12, 2021 8:52 am
Many thanks lander.
I guess I will give the car a good run to get the oil temperature up. With engine still running get under the bonnet and inspect the cam cover seal in the suspect areas.
Still waiting for ramp time to get underneath for a good inspection. Hopefully very soon.
But so far the under tray has always been clean and dry.
As stated previously it isn’t a bad leak. But enough to be really annoying.
steve2003rs6
Post by steve2003rs6 » Thu Aug 12, 2021 11:53 am
Just given the suspect leaking areas at the front corners of the cam covers a good clean with brake cleaner. So should be able to see any leak fairly easily now.
The cam belt is due for renewal in April next year.
Just wondering if I bite the bullet and have both jobs done at Neston.
Capt Ric
Post by Capt Ric » Fri Aug 13, 2021 11:53 am
Steve,
Sorry you are having a run of expenses.
If you can put up with the small leak, I'd be inclined to have it done when you have the cambelt done next year.
Good luck.
Ric
steve2003rs6
Post by steve2003rs6 » Fri Aug 13, 2021 12:47 pm
Hi ric. I can live with it until next year. However my other half is going nuts and wants it sorted. Like yesterday.
I was hoping that the new transfer box seal and turbo oil drain pipe gasket would cure the oil leak.
No such luck.
Must admit it is making a mess of the drive.
Just waiting on Neston to get back to me.
As usual they are very busy.
And yes the last two/three years has been VERY expensive.
But at least I have the comfort of knowing that those jobs have been done and hopefully shouldn’t need doing again for quite some time.
Need to also sort out the insurance as what they would pay out is no where near enough. Considering what I have invested in the car.
steve2003rs6
Post by steve2003rs6 » Sat Aug 14, 2021 12:43 pm
Ok so the cam cover gaskets may not be the problem. Having cleaned both covers with brake cleaner After giving the car a good run yesterday and again this morning. Looked at it this afternoon and they are both still clean and dry.
Local mechanic suspects the oil coolers.
Soon as ramp is available we will give it a real good inspection.
Never rains it pours syndrome.
Almost at the stage where I say sod it let’s have the engine out and go to town on it. Will see what grizz recommends.
steve2003rs6
Post by steve2003rs6 » Sun Aug 15, 2021 9:43 pm
Just a crazy thought. Could this be the dreaded poosey pipe fault ??????
Any comments very welcome.
Mɐʇʇ
Post by Mɐʇʇ » Sun Aug 15, 2021 11:29 pm
Nah, cos the poosey pipe carries coolant.
steve2003rs6
Post by steve2003rs6 » Mon Aug 16, 2021 8:12 am
Thanks Matt. Wishful thinking on my part.
So I guess oil coolers / pipes or corroded unions are the most likely candidates.
Opportunity to Install wagners ???
steve2003rs6
Post by steve2003rs6 » Wed Aug 18, 2021 4:11 pm
All being well. 4 post ramp available tomorrow.
Itching to find the oil leak so we can get it sorted.
If it is the coolers. Will look at wagners.
If front end is coming off will get cam belt done at the same time.
A lot of iffs I know.
Users browsing this forum: Shoppinit, srichards and 95 guests
