The Best Hunting Boots of 2021
d7ve_b
Re: Cool What did you do to your B7 RS4 today?
Post by d7ve_b » Thu May 20, 2021 6:12 pm
Hi,
Relatively new owner here and first time poster...
Today I booked my Avant in at CRS to have the DRC removed and replaced with Koni shocks, due to the near side rear failing and leaking oil onto the drive...
Dave.
Lewbo
Post by Lewbo » Sat May 22, 2021 12:22 pm
I’m also a new B7 RS owner - cabriolet to take advantage of the lovely Scottish summer 😀, below is my wee list :-
1. New shifter knob
2. Changed DRLs to clear bulbs
3. New plastic clutch pin to stop the clutch click
4. Oil, diff and box fluids
5. Spark plugs
6. Test/clean air box flap and manifold flap with VCDS.
7. New drivers Seat belt buckle
8. New G65 Aircon sensor for aircon and regas.
9. Interior and rear plate bulb change to LED’s
10. ECS H pipe install for a slightly better note.
11. Full detail, wax and seal.
12. New centre caps and bolt covers
13. New steering wheel lower trim with badge.
Think that’s about it, future bits as below:-
1. Potential suspension DRC is in good shape at the movement but will probably die at some point. Still undecided PSS9’s or the Komi option for a better ride??
2. New oil cooler probably the forge kit
3. Clutch & fly. OEM or Sachs.
Mark_b
Post by Mark_b » Sat May 29, 2021 4:20 pm
washed it, put some fuel in it, and now trying to finally make my mind up about retaining DRC or switching to coilovers!
temo_wil
Post by temo_wil » Sun May 30, 2021 1:30 pm
Cleaning....
RS-Rated
Post by RS-Rated » Wed Jun 02, 2021 1:36 pm
Lewbo wrote:I’m also a new B7 RS owner - cabriolet to take advantage of the lovely Scottish summer Image, below is my wee list :-
1. New shifter knob
5. Spark plugs
Hey Lewbo my RS4s got an annoying clutch click at the moment. How did you know it was the clutch pin? I was thinking maybe one of the switches. Mine goes away after driving for a little while.
