First spring drive out joys
srichards
Re: First spring drive out joys
Post by srichards » Wed May 12, 2021 12:46 pm
Did a longer run. Now discovered rear brakes are red hot on one side. I should probably just drive to the local indy first trip and get them to unstick everything they unstuck in the service months before :roll:
steve2003rs6
Post by steve2003rs6 » Wed May 12, 2021 1:03 pm
I had a seized rear caliper. Overheated the brake fluid causing total loss of brakes.
Change of underwear moment.
Car was ok on short runs
But after a while on long runs zero brakes.
srichards
Post by srichards » Wed May 12, 2021 2:14 pm
It's lucky the recaros are hose clean!
Booked in already. Also it's doing the faint oil whiff again so they may as well check that out at the same time.
Post by Shoppinit » Wed May 12, 2021 6:55 pm
Just change the caliper. Cheap as chips.
steve2003rs6
Post by steve2003rs6 » Wed May 12, 2021 8:25 pm
Yes Shop that’s what they did to mine. Not had a problem since.
As you say. Rear calipers cheap to replace.
Human Joist
Post by Human Joist » Wed May 12, 2021 9:28 pm
Well cheap for rs. Not cheap for rear calliper and pads in comparison to other cars. But I didn’t expect any less.
Post by Shoppinit » Wed May 12, 2021 9:39 pm
Cheap as gastropub gourmet triple cooked, in goose fat, chips, then.
srichards
Post by srichards » Thu May 13, 2021 9:33 am
I did replace a caliper the other year. Hopefully it's not the same one what's failed.
Apparently not. Replaced the other one exactly 3 years ago.
srichards
Post by srichards » Fri May 21, 2021 4:24 pm
Caliper sorted. Got away with only doing that and not needing discs/pads as I spotted it early. Shame it's got a gearbox and engine oil leak. Arse.
Human Joist
Post by Human Joist » Tue May 25, 2021 12:32 pm
Tie rods bushes swapped out with polly. New bolts and anti roll bar swapped for polly as well. All tracked and back on the road. Feels so planted now
Users browsing this forum: Google [Bot] and 86 guests
