RS4 Weak Points after staging
Hi All, I have recently done a stage 1 on my B9 RS4 and habe been looking for topics or articles on the weak points i.e. transmission mounts, IAT Temps, etc bit not getting any luck... Any tuners out there that can shed some light? Want to go Stage 2 but also want to maintain longevity on powertrain with proper maintenance on these weak point?
Sent from my SM-G973F using Tapatalk
- 1st Gear
Re: RS4 Weak Points after staging
I'm not a tuner by any means but IAT is definitely an issue. Even stock the temperatures are high and I've asked manufacturers that sell tuning boxes about this but non of them will provide me the intake temperatures after the boxes are installed. You can get upgraded intercooler than help I believe
ABT add a extra water cooler with there R kit
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Upgraded intercooler and heat exchanger.
Wagner has a unit available.
2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner intercooler / Radiator| Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm
Yeah , will be getting the Wagner IC and Heat exchange, anyone heard anything about the transmission being an issue or the mounting ? I am already pushing 760nm
Hi there, thinking of going stage 1 with mine. What mods other than a map did you get (if any)?whited.darkwing wrote: ↑Sun Mar 28, 2021 8:58 amHi All, I have recently done a stage 1 on my B9 RS4 and habe been looking for topics or articles on the weak points i.e. transmission mounts, IAT Temps, etc bit not getting any luck... Any tuners out there that can shed some light? Want to go Stage 2 but also want to maintain longevity on powertrain with proper maintenance on these weak point?
Hey sprintblueb7, I have had custom downpipes, non valved cat back, stage 2 map and CAI done for now, seems good, my temps have been good so far so haven't done the charge cooler yet
Users browsing this forum: No registered users and 19 guests
