Sitting lower at the rear, especially the driver's side.
12th
Post by 12th » Thu Mar 18, 2021 8:33 am
The rear of the car is sitting lower, most noticeably on my side. No signs of DRC leakage, though I know it can need repressurising. Plan is (probably) to have DRC replaced, possibly later this year.
Is there anything else that could cause this - knackered dampers? Does the car have separate springs too?
Thoughts greatly appreciated - car owned from new so I know the DRC has never spilled its guts in the garage!
Sprint Blue B7 RS4 Saloon with MRC tweakery.
AA_954
Re: Sitting lower at the rear, especially the driver's side.
Post by AA_954 » Thu Mar 18, 2021 8:44 am
12th wrote:The rear of the car is sitting lower, most noticeably on my side. No signs of DRC leakage, though I know it can need repressurising. Plan is (probably) to have DRC replaced, possibly later this year.
Each side will have its own spring, maybe one of them might have cracked or could be basically worn out
Sent from my iPhone using Tapatalk Pro
12th
Post by 12th » Thu Mar 18, 2021 8:50 am
OK - thanks for that.
12th
Post by 12th » Fri Mar 19, 2021 6:35 pm
Well, in being looked at - apparently there is a levelling sensor there too, so just a case of waiting and seeing...
Pistolpete2543
Post by Pistolpete2543 » Fri Mar 19, 2021 8:01 pm
Be interested to hear the outcome of the investigation. I don’t think there is a levelling sensor though, it’s a purely mechanical/hydraulic system.
coffey555
Post by coffey555 » Fri Mar 19, 2021 10:10 pm
Broken spring or worn out rubber spring seat. As others have stated, there is no level sensor on a B7. If it is still on the original 14 year old springs I would replace even if not cracked as they sag with age.
The B7 always looks like it sits lower at the rear on DRC (either SS or SS+) because of the extra tyre to arch centre gap at the front. You need that so the tyre does not catch on the arch if you hit a pothole with lots of lock on.
What garage are looking at it? Any knocks or clunks when driving?
Misano Red RS4 B7 Avant
12th
Post by 12th » Sat Mar 20, 2021 9:37 am
It's a local indy - used them for many years and much prefer them to main dealer. Turns out both rear springs had gone - have asked them to examine the rest of the suspension to make sure this hasn't broken anything else - will get it back today. They always grease the DRC as well - there is some limited corrosion but this keeps it under control.
I thought the suspension was making some noise over sleeping policeman, but might have been imagining it, as you sometimes can do when you think something's amiss.
Pistolpete2543
Post by Pistolpete2543 » Sat Mar 20, 2021 11:08 am
When you say both rear springs had gone, were they broken or just worn?
12th
Post by 12th » Sat Mar 20, 2021 11:54 am
Broken, I think. Hence wanting to make sure that hasn't caused damage elsewhere.
Pistolpete2543
Post by Pistolpete2543 » Sat Mar 20, 2021 12:11 pm
Cheers for the info, think I need to check mine out too as I've noticed it is lower at the back than I remember it ever was. I might opt for the H&R springs if they need changing.
12th
Post by 12th » Sat Mar 20, 2021 12:45 pm
Yep, they were broken. Ride is markedly improved now.
