Head Up Display
Head Up Display
Hi all!
Am new to the forum, I am from Singapore and I just bought an UK export brand new RS4 B9.5 carbon black pack.
I realised it doesn't has head up display, is it an option?
Re: Head Up Display
i was an option in the pre facelift model when you spec'ed the car yopurself
but now they have trim levels for the car it is only availble on the Vorsprung adition
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re: Head Up Display
It is a standard option on Singapore spec cars, but not on UK spec unless Vorsprung edition.
The other option that you don’t have is memory seat, but is standard on Singapore spec cars.
Re: Head Up Display
yes the |UK have went away from induivual spec and are only doning trim levels now that you can tweeek slightly but not to the point you could before
the likes of Gremany you can spec the car any way you want i dont know why Audi UK have done this it a bit of a pain
- Graeme4130
Re: Head Up Display
I found it a bit crap to be honest. You can't see it if you wear polarised sunglasses, which nearly every decent pair of ray bans or Oakleys are, so it's only any use at night or when you're not wearing sunnies
Re: Head Up Display
I dont find it hard to see with sunglassesGraeme4130 wrote: ↑Fri Nov 06, 2020 6:23 pmI found it a bit crap to be honest. You can't see it if you wear polarised sunglasses, which nearly every decent pair of ray bans or Oakleys are, so it's only any use at night or when you're not wearing sunnies
But it would be nice to remove the timer from the 2nd setting
Re: Head Up Display
Confirmed: can’t see it when a good pair of polarised lenses onBrooner wrote: ↑Fri Nov 06, 2020 7:10 pmI dont find it hard to see with sunglassesGraeme4130 wrote: ↑Fri Nov 06, 2020 6:23 pmI found it a bit crap to be honest. You can't see it if you wear polarised sunglasses, which nearly every decent pair of ray bans or Oakleys are, so it's only any use at night or when you're not wearing sunnies
Confirmed 2: I wrote Audi to remove the stupid timer from RS mode and to put the rpm scale as they did for RS7. Thank said “thanks for your feedback will work on it”and probably throw away my mail. You know, who cares about MIB2 customers now that the new MIb3 is default.
Re: Head Up Display
There is RPM indicator lights on the top of the HUD
But its only seen in manual mode
Re: Head Up Display
Yes you are right. The rpm indicator lights appears on top of the no sense timer only when you approach the red zone in term of rpm. I would have preferred to see all the range.
Re: Head Up Display
Ok didnt know the RS7 had a full rev counter on the HUD
Users browsing this forum: Brooner and 6 guests
