Intake swirl flaps
irn_bru_ce
Intake swirl flaps
Post by irn_bru_ce » Fri Nov 20, 2020 2:29 pm
So by now must be a decent ammount of cars without swirl flaps. My car is currently in for the MOT but the CEL is on due to flap issues. Can I just pick some peoples brains, I take it there is a vacuum powered actuator on each bank to drive the flaps, and a position sensor to report to the ECU the position of the flaps, are they equally prone to failure, and what is the approx cost of the actuators and the sensors, if they are seperate items?
When people delete the flaps, what parts are actually being removed, is the vacuum actuator and sensors being left in to move without any actual flaps being installed, or does the whole lot get removed?
When anything is removed, I assume the ECUs need changed in some way, can this be done with VCDS or is it a bigger job requiring a new map to be written?
rocket1
Re: Intake swirl flaps
Post by rocket1 » Sat Nov 21, 2020 12:20 am
If the actuators are left in place and just the flaps removed it should be fine. If the whole lots been removed then its a remap time to code them out and stop error codes and lights.
rs4 b7 daytona avant. Miltek resonated valved, Mrc stage 2
vw touran 2.0tdi, blue /black leather. family wagon!!.
repsol honda fireblade.
Zx12r b1 in black and gold. The colour to have!!
Users browsing this forum: dan32v, Google [Bot] and 207 guests
