So by now must be a decent ammount of cars without swirl flaps. My car is currently in for the MOT but the CEL is on due to flap issues. Can I just pick some peoples brains, I take it there is a vacuum powered actuator on each bank to drive the flaps, and a position sensor to report to the ECU the position of the flaps, are they equally prone to failure, and what is the approx cost of the actuators and the sensors, if they are seperate items?
When people delete the flaps, what parts are actually being removed, is the vacuum actuator and sensors being left in to move without any actual flaps being installed, or does the whole lot get removed?
When anything is removed, I assume the ECUs need changed in some way, can this be done with VCDS or is it a bigger job requiring a new map to be written?
Intake swirl flaps
Intake swirl flaps
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
Re: Intake swirl flaps
If the actuators are left in place and just the flaps removed it should be fine. If the whole lots been removed then its a remap time to code them out and stop error codes and lights.
repsol honda fireblade.
Users browsing this forum: highrise and 143 guests
