How to change starter motor on Audi RS4
Here is a quick tutorial on how to change your starter motor on your RS4 B7.
time needed 3-5 hours
difficulty 6
https://youtu.be/KDAOlev7l-g
difficulty 6
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Re: How to change starter motor on Audi RS4
Excellent I need to do this.
Well done Ilya, I watched the video too
Good how to - cheers for the video.
Would you happen to know the part number for the 3 stretch bolts that are removed when taking off the first bracket?
I need to get access to the starter connectors but don't need to remove / replace the starter itself.
Cheers for any info.
Mike
Mike
Been looking further into the part number.
Could anyone confirm its number 25 on this diagram please:
https://audi.7zap.com/en/rdw/audi+rs4+a ... 199000/#25
part number N91025301 - M10x52, does this sound right?
Mike
Mike
This needs to go in the ‘sticky’ how to do
These N90331606 number 3 on the parts listmikep99 wrote: ↑Tue Sep 15, 2020 1:55 pmBeen looking further into the part number.
Mike
ok, cheers.docurley wrote: ↑Tue Sep 15, 2020 4:14 pmThese N90331606 number 3 on the parts listmikep99 wrote: ↑Tue Sep 15, 2020 1:55 pmBeen looking further into the part number.
Mike
That makes more sense to me.
I think in the video its implied that the 1st 3 bolts removed are stretch bolts...
ta
Mike
Just to complement the video above, I've just noticed there's a section on how to replace the starter in a workshop manual I have.
I've attached a PDF with the relevant pages. It assumes you've taken the undertray off and supported the engine.
ta
Mike
ta
Mike
- Attachments
- starter.pdf
- (537.91 KiB) Downloaded 231 times
Good luck doing it off the floor it ain't easy
We've done it already!!!
cracking guide-tbh looks about the same amount of graft as changing a clutch in any of the tdi fwd vag group lol
just seen this, fantastic vid
I had a starting issue with min a couple of years ago (separate article on here), mine turned out to be high resistance infact higher than the torque output of the starter motor, turned out to be an issue with one of my cams not turning freely resulting in no start, no similar scenarious anywhere on the internet....but that to one side well done
Users browsing this forum: No registered users and 40 guests
