TCU
Re: TCU
Logs measuring blocks 005 and 006 along with group 001 to get the input rpms and current gear.
Remind me what your error codes are?
Re: TCU
So many fault codes that could all be explained by a bad 16-pin connector at the gear box. Or a bad TCU.
How do you feel about measuring resistance?
Re: TCU
I measured the resistance on the harness at the front that’s known to corrode because of the seals
And it was fine. Used contact cleaner and reconnected. I haven’t been able to find a spare TCU to try out I live in Canada and there’s not many of these here
Re: TCU
Plug it back in and unplug from the TCU to check the resistances.
Re: TCU
Measure between pins:
52 & 53
33 & 52
33 & 34
32 & 52
32 & 34
Ignition off.
52 & 53
33 & 52
33 & 34
32 & 52
32 & 34
Ignition off.
Re: TCU
Yup.
Re: TCU
When you say nothing do you mean zero or infinity?
Re: TCU
OK. Then infinity.
So what you measured is all as I would expect it to be.
That would suggest it's not the 16 pin connector and not the solenoids. So maybe a bad TCU.
Where in Canada are you?
Re: TCU
Niagara Falls Ontario.
My tuner said he would be able to take apart the TCU and diagnose and fix if he can for around C$400 although I don’t really see a very good track record when people Muck around with the tcu
Re: TCU
You could try calling Xemodex to see if they can do anything. They’re in Ontario IIRC. I don’t know if they do anything on the RS6 TCU though.
Users browsing this forum: No registered users and 139 guests
