Finally hit with a DRC bill! PLEASE HELP ME!!!
Re: Finally hit with a DRC bill! PLEASE HELP ME!!!
Think it depends mate on how bad it is. If its just a split hose then surely replace that hose (£210) and system recharge for the oil thats been lost. If the shocks are leaking (£550) each. If you don't have a warranty, probably better to replace with something else as the bill will be big as they will go eventually. It cost just under £2500 for my front shocks, 2 hoses and system recharge. If the whole system needs done, the cost is horrific
Thanks, no warranty.... replacement on the cards it looks like, just waiting for a reply on here to confirm some parts.... it was good while they lastedJaseB wrote:Think it depends mate on how bad it is. If its just a split hose then surely replace that hose (£210) and system recharge for the oil thats been lost. If the shocks are leaking (£550) each. If you don't have a warranty, probably better to replace with something else as the bill will be big as they will go eventually. It cost just under £2500 for my front shocks, 2 hoses and system recharge. If the whole system needs done, the cost is horrific
Are you guys happy with the aftermarket replacements?jangol wrote:Thanks, no warranty.... replacement on the cards it looks like, just waiting for a reply on here to confirm some parts.... it was good while they lastedJaseB wrote:Think it depends mate on how bad it is. If its just a split hose then surely replace that hose (£210) and system recharge for the oil thats been lost. If the shocks are leaking (£550) each. If you don't have a warranty, probably better to replace with something else as the bill will be big as they will go eventually. It cost just under £2500 for my front shocks, 2 hoses and system recharge. If the whole system needs done, the cost is horrific
My reasoning behind fixing mine was that numerous people told me “you can’t beat DRC on a b8 when it’s working” along with the fact that my shocks 50,000 miles in and I’ve only had to replace the front ones. If I get 50,000 miles plus out of each set I’m happy to be honest. Then there is the resale value with aftermarket parts on. I’ll B8’s going for less with non-OEM suspension?
I see the occasional burst pipe and recharge as general maintenance on this car.
Thoughts?
I couldn’t be more happy with the KW V3’s.
They are at the KW recommended setting and ride superbly.
UAE CARS
2009 Toyota Landcruiser - White -4.7 V8 VXR (SOLD)
2014 Mercedes ML500 - 4.7 V8 Twin Turbo (SOLD)
2008 Audi RS4 - Sprint Blue (SOLD)
2002 Range Rover 4.6 V8 HSE (SOLD)
2007 Golf R32 - Black (SOLD)
2005 Lincoln Navigator - White (SOLD)
UK Cars
2015 Landrover Defender 110 Heritage (SOLD)
2014 Audi RS4 - Sepang Blue (STOLEN)
2003 EP3 Civic Type R - K-Pro Remapped (SOLD)
2004 Golf GT TDi 140 - Superchipped to 189bhp (SOLD)
2003 Audi A2 1.4 Tdi
UK Cars
I will be keeping the DRC on mine as I will keep the warranty going. Like to keep the car standard. Each to the own I suppose as I can see how people could get fed up paying out on the DRC every so often, depending on mileage, age etc if they could get another system that will last the life of the car.
My car only had only covered 28k when the front shocks needed replaced. Think it depends on the roads you travel as well. Pot holes everywhere!
- Trader (Expired)
As you may or may not know we ( CRS Performance ) have rescued many B7 RS 4 from the 3 to 4 grand bills for DRC repairs , 100 % success no customer complaints at all . Most comment that it is better than original after we supply and fit our custom RS4 kits , The B8 cars are now starting to give hassles and most out of warranty so customers are looking for an economical fix with out compromising the performance or comfort ,
We have done quite a few B8 RS4 cars now and get the same results as we do with the B7 RS4
The added complication is of course the addition of the electronics into the shocks , This is taken care of with a Delete Kit .
The electronic functionality is that when selecting Sport mode the shocks stiffen Up . On rougher roads you would generally leave the selector on comfort where the dampers are softer to cope with the poor road surface .
THE CRS kit uses KONI technology which actually works the opposite way around . There fore the shocks on smooth surfaces are stiffer to give great handling and when they move fast , which means a bumpy service they will feel softer , more comfort . You can have the best of both worlds BUT with out having to select it , No lose of functionality. THe delete kit does push the price up close to a Grand but compared to Audi this is a "no brainer" .
As for second hand Value and originality , I personally would be far happier buying a car that has had these after market bits installed because i would worry that i could be in for a huge bill to sort the DRC out buying a standard Car . Many of the customers agree with this , and i know the purest of us out there wont agree , but staring down the barrel of a 3 to 4 grand bill to keep originality is something many wont do if there is a solid alternative .
The other thing is that the car can remain standard height , this is often a problem not anticipated when fitting after market coil overs which cant do standard height and often ride too firm when low .
Bit the bullet & replacing the DRC...with the Koni setup & HR springs... will let you know what o think once it’s done next weekJaseB wrote:Think it depends mate on how bad it is. If its just a split hose then surely replace that hose (£210) and system recharge for the oil thats been lost. If the shocks are leaking (£550) each. If you don't have a warranty, probably better to replace with something else as the bill will be big as they will go eventually. It cost just under £2500 for my front shocks, 2 hoses and system recharge. If the whole system needs done, the cost is horrific
Nice one. Hope it all goes well. Would be interested to hear how the ride compares on less than perfect road surfaces. My car is standard DRC and feels great on immaculate roads but can be harsh on average roads. Am curious to hear if the new setup improves that.
Heard some decent reviews, so willhindsight wrote:Nice one. Hope it all goes well. Would be interested to hear how the ride compares on less than perfect road surfaces. My car is standard DRC and feels great on immaculate roads but can be harsh on average roads. Am curious to hear if the new setup improves that.
Keep you posted on that.. I’m
Assuming as this setup is with newer technology/research etc it will have in mind our poor road surfaces....
jangol wrote:Heard some decent reviews, so willhindsight wrote:Nice one. Hope it all goes well. Would be interested to hear how the ride compares on less than perfect road surfaces. My car is standard DRC and feels great on immaculate roads but can be harsh on average roads. Am curious to hear if the new setup improves that.
How would we go about ordering the CRS Performance kit for B8 RS4. Was considering KW V1's but these sound like an option?
To be fair Steve was very helpful, & quick turn around for parts, getting installed tomorrow or Thursday, I’ll PM you his number, worth a chat with himWingnuttzz wrote:How would we go about ordering the CRS Performance kit for B8 RS4. Was considering KW V1's but these sound like an option?
- Rugslasher
- 1st Gear
Well I’m a few hundred miles on the new KW V3’s & a superb difference, the car feels more planted & can even say nimble for a nearly 2 ton beast , I have got a set of hoses for the DRC shocks less than 3,000 mile use if anyone needs any as it was the front shock that gave way after doing pipes 4 months before
Good to hear the replacement suspension is up to the job and theres a decent alternative to the DRC
Users browsing this forum: No registered users and 74 guests
