Coolant leak under my 2016 RS6 with only 60'000km
Hitman70
Post by Hitman70 » Sat Nov 07, 2020 12:44 am
Hi,
Today I just noticed a bad coolant leak under my RS6.
This leak occured after 2 days without driving the car (yesterday wasn't there I'm 100% sure) so it seems that letting the car cold for a long time cause it.
I'll call my dealer monday, my car have warranty, but I'm worried. Do you know what it coups be? Waterpump?
The liquid is dripping from a small rubber grill under the car (see attached)
My RS6 only have 4 years / 60'000 km :cry:
morski
Re: Coolant leak under my 2016 RS6 with only 60'000km
Post by morski » Sat Nov 07, 2020 12:22 pm
Until the front end is partially dismantled and then pressure tested its very difficult to say where it could be coming from. There is a huge number of pipes there especially on the left. Water pump & thermostat is there and its joints can weep
davers6
Post by davers6 » Sat Nov 07, 2020 12:53 pm
Are you sure it’s coolant and not condensation from air con
morski
Post by morski » Sat Nov 07, 2020 2:59 pm
Air con condensate outlets are on the transmission tunnel
Hitman70
Post by Hitman70 » Sat Nov 07, 2020 3:02 pm
Yes sure, it's purple with chemical smell and it doesn't dry from floor.
innercry666
Post by innercry666 » Sat Nov 07, 2020 8:05 pm
There's a common issue with the water pump housing leaking, so check for coolant crusted around the water pump. I had the same on mine last year at just over 3 years of age.
RS6 PE - Current
RS4 (B8.5) 2015 - Sold
A4 3.0 TDI Quattro BE Avant - Gone
Focus ST170 - Garaged
Hitman70
Post by Hitman70 » Sat Nov 07, 2020 8:17 pm
Ahh OK and you had to change the whole waterpump?
innercry666
Post by innercry666 » Sun Nov 08, 2020 1:20 am
Correct. It was carried out under the extended warranty with no quibble from Audi. They had a TPI on it as well. To get access to it to I believe they had to take the front of the car off.
RS6 PE - Current
Hitman70
Post by Hitman70 » Sun Nov 08, 2020 6:36 am
Ye that's my fear... I'm scared that I may then have bad alignment of the front of the car... Or some scratches :oops:
My car is 4 YO, your was 3 YO, it's way too early for a water pump fail. Is it a known issue? What was your mileage when it happened?
morski
Post by morski » Sun Nov 08, 2020 12:57 pm
Heres some info on the 4.0tt leak
4.0tt thermostat leak info.pdf
(1.12 MiB) Downloaded 767 times
Hitman70
Post by Hitman70 » Sun Nov 08, 2020 2:04 pm
Thanks! Very interesting documentation!!
It's surprising that a small coolant leak can even be "normal" as it lubricates the seal (page 34).
But my leak is more than small as it do a spot on the floor (did 2 times in 3 weeks, so it doesn't leaks everyday) so it may be a faulty water pump.
morski
Post by morski » Sun Nov 08, 2020 2:55 pm
Just highlights the fact that Audi do know about it in all its various forms of leakage
innercry666
Post by innercry666 » Wed Nov 11, 2020 3:10 pm
It was probably around 20K miles.
RS6 PE - Current
innercry666
Post by innercry666 » Wed Nov 11, 2020 3:17 pm
Just read the document attached above and the indication of coolant traces on the thermostat housing align with what was found on mine as per the attached photograph
RS6 PE - Current
Hitman70
Post by Hitman70 » Sun Nov 15, 2020 3:51 pm
Thanks for the informations.
So it seems that my car do lose coolant ONLY if it stays long time without drive, more than 24h.
All the past week, I drove my car everyday and I didn't had any leak (no missing coolant, no coolant spots on the floor).
For try, I decided to let my car in my garage for all the weekend. Yesterday, I looked under my car after about 24h without driving --> no spot
This morning i checked after about 36h --> leak started! A spot on the floor and some coolant leaking from a hole under the car...
I'll leave it thursday and friday to the dealer for check/repair under warranty, but I'm really affraid that they can damage/scratch misallign something as they will have to take off the front bumper of my car -_-
