Advice on replacement battery
HDPete
Post by HDPete » Thu Nov 05, 2020 11:13 am
My battery is just over 4 years old. The car threw an MIL light last week. After checking the codes they were all low voltage related. I then conditioned the battery with my Ring charger which got to 60% but then reported F05, which is where it can’t maintain the battery. I do short trips mainly and the auto stop start never works.
So it’s looking like I need a replacement.
I headed over to Euro Car Parts and found they suggest a battery that’s £500. :drink: Surely that can’t be right?
Is there a general consensus for which battery size, make and cost?
Pete
morski
Re: Advice on replacement battery
Post by morski » Thu Nov 05, 2020 1:34 pm
£500 is way off. Dont even think about it.
Your original battery will probably bee either a 95-110Ah battery and even a genuine one from Audi/TPS will cost from £210-£235 inc vat and a similar one from a reputable battery place should be £150-£175.
Make sure you get an AGM for the stop start system and any big brand ie Yuasa,Varta, Bosch etc will carry a 4+year warranty.
Also if you have VCDS you will need to code the new battery to the car in the CAN gateway just so the car knows that the battery has been replaced and can apply the correct charging etc
HDPete
Post by HDPete » Thu Nov 05, 2020 1:43 pm
Fantastic! Thanks Morski. Is there any guidance on where I need to go in VCDS to do that?
don0301
Post by don0301 » Thu Nov 05, 2020 2:35 pm
I recently had to replace the battery on my C6 RS6, I had been using a CTEK to maintain the battery but this year has obviously affected it.
Mine uses a non-AGM 110A 020 battery. Although an AGM battery is also recommended for my car!
A quick google search found a non-AGM VARTA battery with 5 year warranty for £109.50, a pleasant surprise! the AGM version was £195.
If you go to the VARTA site and put your car details in, it should show you the correct spec battery to get, if you can't be arsed looking at your battery yourself.
It will also point you to retailers, but I found cheaper online.
Since the new battery fitted, several voltage/current anomalies have disappeared in my VCDS.
I couldn't get any info regarding battery code, I just changed the code with VCDS by one number, all sweet.
just google VCDS battery code should point you to the procedure on your car. Straight forward. Just make a note of the old code just in case.
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah :shock:
morski
Post by morski » Thu Nov 05, 2020 4:12 pm
MountainMutant
Post by MountainMutant » Thu Nov 05, 2020 7:15 pm
Where is the battery? My old C5 was in the boot floor but I have the air suspension on my car and no battery there.
2017 RS6 PE Nogaro 💙
morski
Post by morski » Thu Nov 05, 2020 8:08 pm
Its in the boot. Air suspension tank is bolted directly in front of battery or behind depending on which way you look at it
Tadass910
Post by Tadass910 » Mon Nov 09, 2020 4:28 pm
I am on original battery from 2014 April still running fine
Lig
Post by Lig » Wed Nov 11, 2020 3:08 pm
Hi hdpete,
No coding required... have a look at this thread...
viewtopic.php?f=76&t=132632&p=919953&hi ... ry#p919953
Cheers,
Lig.
HDPete
Post by HDPete » Wed Nov 11, 2020 6:12 pm
Thanks Lig!
morski
Post by morski » Thu Nov 12, 2020 9:30 pm
These cars have a battery monitoring control module fitted to the -ve terminal that monitors its current etc so he new battery will need coding to the car. Simple process.
Users browsing this forum: Bing [Bot], Google [Bot], goram and 40 guests
