Adaptive light fault after lowering
4.2 V8 32v FSI - 444 bhp
Rs4b8AA
Re: Adaptive light fault after lowering
Post by Rs4b8AA » Tue Nov 03, 2020 9:28 pm
Rugslasher wrote:
Tue Nov 03, 2020 8:38 pm
These
Perfect, Thanks! - Exactly what i did order, only the front though
Was both bad for you?
Rugslasher
Post by Rugslasher » Tue Nov 03, 2020 10:03 pm
It’s probably just the front on mine but ordered both just in case
Rs4b8AA
Post by Rs4b8AA » Sat Nov 07, 2020 1:23 pm
I now changed my left front sensor. Level error code is gone but still adaptive fail code... I will now try to change bulbs.
Rugslasher
Post by Rugslasher » Sat Nov 07, 2020 4:00 pm
Mine still had adaptive error so deleted code & hopefully sorted
Rs4b8AA
Post by Rs4b8AA » Sat Nov 07, 2020 4:41 pm
Ok, but can you see if the lights are moving when you turning?
Can you believe, first when i try to mount the level sensor i cant fint the locking nut, now when i want to change the bulbes i cant open the fooocking hood! (I did loose many panels to try check the wire under the wheel but all looked good.) Now i will haft to wait to monday!
Edit: Just test drive in the dark, my adaptive does not work and i still got the error code.
Rugslasher
Post by Rugslasher » Sun Nov 08, 2020 11:27 am
Mine has always done the up /down/left & right on startup, but tbh I think mine just needed resetting due to lowering , I just thought it was the sensor as I did a lot of hammering changing the front stub axle , if mine comes back on I’ll have to recalibration on vag when I find out the codes
Rs4b8AA
Post by Rs4b8AA » Fri Nov 20, 2020 5:34 pm
Any progress on this?
Rugslasher
Post by Rugslasher » Fri Nov 20, 2020 7:11 pm
Yes all working as it should 🤞🏻
Users browsing this forum: Thedarkside and 41 guests
