Perfect, Thanks! - Exactly what i did order, only the front though
Was both bad for you?
I now changed my left front sensor. Level error code is gone but still adaptive fail code... I will now try to change bulbs.Rugslasher wrote: ↑Tue Nov 03, 2020 10:03 pmIt’s probably just the front on mine but ordered both just in case
Ok, but can you see if the lights are moving when you turning?Rugslasher wrote: ↑Sat Nov 07, 2020 4:00 pmMine still had adaptive error so deleted code & hopefully sorted
Any progress on this?Rugslasher wrote: ↑Sun Nov 08, 2020 11:27 amMine has always done the up /down/left & right on startup, but tbh I think mine just needed resetting due to lowering , I just thought it was the sensor as I did a lot of hammering changing the front stub axle , if mine comes back on I’ll have to recalibration on vag when I find out the codes
