Adaptive light fault after lowering
- Rugslasher
- 1st Gear
So I’ve just done the kw v3’s & after doing a long drive up to Gretna Green (170miles) I set off home this morning & after around 70miles the adaptive lights malfunction notification pinged up & stays on ???? Is this due to lowering the car or just coincidence, all the lights still work etc so wondering if anyone has had similar issues
Re: Adaptive light fault after lowering
Sounds like coincidence, I had the same malfunction notification on my B8. Bought a headlight ballist from eBay £30ish. Sits under the headlight 10min fix.
Rs4 b8 Sepang blue
Rs5 b9 Riviera blue
Rs5 b9 Riviera blue
RSrichmond wrote: ↑Tue Oct 27, 2020 10:02 pmSounds like coincidence, I had the same malfunction notification on my B8. Bought a headlight ballist from eBay £30ish. Sits under the headlight 10min fix.
Do you perhaps have any link (partnumber) for this item that works with B 8.5 (RS4) adaptive? (I got the same issue even if i dont have lowered the car)
Thanks in advance!
Rs4 b8 Sepang blue
Rs5 b9 Riviera blue
Rs5 b9 Riviera blue
Thank you RSrichmond
Not sure if you have sorted this issue but I would think the fault would be related to the level sensors on the nearside
- Rugslasher
- 1st Gear
Not had a look yet but was thinking the same as I had to change near side stub axle so had to reattach the link rod between the sensor & lower armB1ncc 1.8t wrote: ↑Sun Nov 01, 2020 8:29 amNot sure if you have sorted this issue but I would think the fault would be related to the level sensors on the nearside
They are bad for seizing up and they are pretty delicate little things. I couldn’t find any live data on VCDS for them.
Both mine were seized and freeing them off didn’t help.
I fitted two new ones all good now.
- Rugslasher
- 1st Gear
Cheers for info, are they stealer part only ?B1ncc 1.8t wrote: ↑Sun Nov 01, 2020 10:06 amThey are bad for seizing up and they are pretty delicate little things. I couldn’t find any live data on VCDS for them.
Not sure mate. I got two from TPS I didn’t phone Euro etc. Just wanted audi ones
They cost 260 for the pair.
Item 1 is the part number for the front, and item 8 is for the rear. If you google these part numbers you’ll find various options for parts (genuine and aftermarket).Rugslasher wrote: ↑Sun Nov 01, 2020 11:28 amCheers for info, are they stealer part only ?B1ncc 1.8t wrote: ↑Sun Nov 01, 2020 10:06 amThey are bad for seizing up and they are pretty delicate little things. I couldn’t find any live data on VCDS for them.
UAE CARS
2009 Toyota Landcruiser - White -4.7 V8 VXR (SOLD)
2014 Mercedes ML500 - 4.7 V8 Twin Turbo (SOLD)
2008 Audi RS4 - Sprint Blue (SOLD)
2002 Range Rover 4.6 V8 HSE (SOLD)
2007 Golf R32 - Black (SOLD)
2005 Lincoln Navigator - White (SOLD)
UK Cars
2015 Landrover Defender 110 Heritage (SOLD)
2014 Audi RS4 - Sepang Blue (STOLEN)
2003 EP3 Civic Type R - K-Pro Remapped (SOLD)
2004 Golf GT TDi 140 - Superchipped to 189bhp (SOLD)
2003 Audi A2 1.4 Tdi
UK Cars
- Rugslasher
- 1st Gear
matthew.lewis2 wrote: ↑Sun Nov 01, 2020 2:37 pmThanksRugslasher wrote: ↑Sun Nov 01, 2020 11:28 amCheers for info, are they stealer part only ?B1ncc 1.8t wrote: ↑Sun Nov 01, 2020 10:06 amThey are bad for seizing up and they are pretty delicate little things. I couldn’t find any live data on VCDS for them.
- Rugslasher
- 1st Gear
So I’ve had a look on the web & ordered front & rear sensors £63 posted so hopefully solve the issue
I am lost here, still waiting for my adaptive lights that i orderd from ebay. Can ypu perhaps guide me in a photo on witch sensors you are talking about?B1ncc 1.8t wrote: ↑Sun Nov 01, 2020 10:06 amThey are bad for seizing up and they are pretty delicate little things. I couldn’t find any live data on VCDS for them.
Thanks in advance
- Rugslasher
- 1st Gear
Users browsing this forum: Majestic-12 [Bot] and 40 guests
