Audi RS6 full injectors
Hi guys.....
Need Some help Abut the Full injectors the OEM IS TO EXPENSIVE
SO I FOUND AFTER MARKET FULL INJECTORS *huco* AND HITACHI FOUND IT IN GOOD PRICE
Did any one Try it....?
Did Anyone Recommend it After market or stick On The OEM....?
Wasn't aware of aftermarket injectors, but I'm new to rs6 so hopefully someone here may have more insight on this topic.
Re: Audi RS6 full injectors
Personally i'd stick OEM as when i had an injector go down on my old C6 it stuck open and caused me bore wash meaning the engine had to be removed....
A new injector was £125 from TPS so i dont think they are "that" expensive really.
The bill for engine removal and rehone was over £4000 i'd rather invest that little bit extra in an OEM injector than have my engine removed because a cheap injector stuck open.
Just my opinion though!
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2017 Mercedes E63S W213 1033/1400nm
2013 Mercedes E63S W212 740/1200nm
2010 Nissan GT-R SVM 680R
2010 RS6 C6 Avant Stage 2 730/1088nm
I think i will stick on the OEM your right
Resurrecting this thread.
Out of curiosity, are they prone to fail on C6’s?
What are the symptoms of a ‘failed injector’ on FSI engines?
Thanks!
Thanks!
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
- H&R ARBs
While this place isn't an exhaustive list of C6 owners, I think there has only been a few people having an injector issues on here. As for symptoms here is a list of threads people started describing their symptoms -
TomRS
viewtopic.php?f=47&t=116937&p=757773
Adam1411
viewtopic.php?f=47&t=126124&p=871040
McF reported a failed a failed injector as a reply to someone else but gave no symptoms.
TomRS
Adam1411
***NEW*** Daytona C6 RS6 Avant - MRC'd - 955HP & 1200NM (PistonHeads Link)
It depends on how it fails.
I had an injector driver fail on another car and hold wide open. Symptoms were loss of power and white smoke/reek of fuel from the exhaust.
Thanks chaps - that’s really useful.
Is there a way to check (via VCDS or any other tool) whether they are working as expected?
- H&R ARBs
- H&R ARBs
Fuel rail pressure checks, error messages and cylinder misfires (if its stuck closed rather than open) would be a good set of checks.
Two new injectors and the car drives like a dream now.
FYI - MRC map 'hides' misfire errors... when out back on stock, it was much easier to diagnose the fault.
- H&R ARBs
- H&R ARBs
Users browsing this forum: lozza2702 and 54 guests
