15mm spacers
Re: 15mm spacers
Post by MikeFish » Sun Jun 07, 2020 12:52 am
OK, that definitely makes it air and not DRC. As an alternative to the CETE module you can buy adjustable links that replace the standard slef leveling links. By changing the length of them you trick the car into thinking it is sitting higher than it actually is so it lowers the ride height more. Cheap and easy to fit
Paddski
Re: 15mm spacers
Post by Paddski » Mon Jun 08, 2020 9:14 am
MikeFish wrote:OK, that definitely makes it air and not DRC. As an alternative to the CETE module you can buy adjustable links that replace the standard slef leveling links. By changing the length of them you trick the car into thinking it is sitting higher than it actually is so it lowers the ride height more. Cheap and easy to fit
That’s an option but to be honest I like the idea of the CETE as you can adjust easily from app
RS6 Performace C7
Honda NSX 2017
Ford Licensed Shelby 1966 350GTH Replica......in build.....
Porsche Cayman GT4 Agate Grey...Wrapped Matte Blue, sold
RS4 B7, 2007, 20" HRE P40's + MRC mods
Bentley Continental GT Titan 600hp, sold
L200 Barbarian, sold
Re: 15mm spacers
Post by MikeFish » Mon Jun 08, 2020 11:18 am
It is worth noting that H&R do black spacers and black bolts. for the black versions add a 'B' to the start of the part numbers.
Tausif
Re: 15mm spacers
Post by Tausif » Mon Oct 05, 2020 9:38 pm
Can anyone recommend where to purchase the H&R hubcentric spacers with the longer wheel bolts.
Im after the 15mm rear and 12mm front spacers?
A link to purchase would be help
TIA
