Just a sanity check when talking to a garage:
When converting an RS4 B7 from a stock DRC to a coilover setup (KW V3, in particular), how many hours of labour shall the operation take?
Coilover conversion - labour time?
Re: Coilover conversion - labour time?
depends on a few things-to remove strut easily the front pinch bolt must come out-or here is extra time to remove the front upper arms from upper mount
to fit and set up i would budget for 3- 4 hrs with most give or take-and dependant on what method they use for existing rear spring removal
some may be a little quicker-some a little slower
Think I was billed for 5.5 / 6 hours labour for coilovers & all front arms replaced.
HTH
Mike
Sent from my PRA-LX1 using Tapatalk
HTH
Mike
sounds fair-tops are almost a while you are there job maybe extra half hour a side max[again if pinch bolt isnt solid],lowers would add a bit of time too
What front arms did you replace them with and where did you get them?. Thanksmikep99 wrote:Think I was billed for 5.5 / 6 hours labour for coilovers & all front arms replaced.
HTH
Mike
Sent from my ONEPLUS A6013 using Tapatalk
Current
'07 - Audi RS4 Avant Daytona Grey
'16 - BMW M135i F20 (LCI)
'53 - Land Rover Range Rover Vogue 4.4 V8
Gone
'02 Audi 8L A3 1.9 TDI (PD)
'03 Subaru Impreza WRX STI
'96 VW Golf VR6
'91 Toyota MR2 NA
'90 Peugeot 205 GTI 1.9
'90 VW Mk2 Golf GTI 8V
Gone
'96 VW Golf VR6
'91 Toyota MR2 NA
I got the Meyle HD set from https://www.ebay.co.uk/itm/162769367607 ... 2769367607jamiej wrote: ↑Mon Sep 28, 2020 9:40 pmWhat front arms did you replace them with and where did you get them?. Thanksmikep99 wrote:Think I was billed for 5.5 / 6 hours labour for coilovers & all front arms replaced.
HTH
Mike
Mike
Cheers Mike.
Current
Gone
'96 VW Golf VR6
'91 Toyota MR2 NA
Gone
'96 VW Golf VR6
'91 Toyota MR2 NA
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 113 guests
