Hello, has anyone encountered a fault code for their thermostat before? The temperature on the car seems fine - fluctuates 92-101º, but the engine bay is the hottest on any car I've encountered.
1 Fault Found:
7036 - Thermostat for Mapped Engine Cooling (F265)
P0597 00 [032] - Open Circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 111497 km
Date: 2020.08.14
Time: 09:51:49
Engine speed: 3431.50 /min
Normed load value: 12.2 %
Vehicle speed: 30 km/h
Coolant temperature: 79 °C
Intake air temperature: 51 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.041 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0010 1001
P0597 thermostat fault "Thermostat for Mapped Engine Cooling" - solved
Re: P0597 thermostat fault "Thermostat for Mapped Engine Cooling"
Just following up - thermostat is being replaced by the warranty company next weekend. If that fixes the code, I'll confirm for future searchers.
Just confirming as promised - I had this fault code, ultimately resolved with replacement of the thermostat. Part number 079121115BL. Took my mechanic 4 hours of labour, and the engine light went off and did not return.
Re: P0597 thermostat fault "Thermostat for Mapped Engine Cooling" - solved
Thanks for you anwser. Same fault.
Very usefull.
Very usefull.
Audi RS6 C7 2014 Black
Akrapovic downpipe + ABT exhaust
Stg 1 - 650hp
Ceramic bkakes
Stg 1 - 650hp
Ceramic bkakes
Users browsing this forum: No registered users and 26 guests
