Flap delete, carbon clean & how to achieve a louder exhaust note without breaking the budget ?
James1984
Re: Flap delete, carbon clean & how to achieve a louder exhaust note without breaking the budget ?
Post by James1984 » Fri Aug 14, 2020 7:27 pm
Give AAS Exhausts in Newcastle a call, they can for £55ish send you a set of top hat shaped aluminium replacements, just tap them in and you are good to go.
Adymars
Post by Adymars » Fri Aug 14, 2020 9:25 pm
Cheers James but I will leave it to the pros and have peace of mind !
Sent from my SM-N976B using Tapatalk
Fatneck73
Post by Fatneck73 » Thu Sep 03, 2020 10:07 am
coffey555 wrote:
Sun Jul 26, 2020 11:00 pm
Just get the centre res section cut out and replaced with two bits of the straight pipe. X-pipe will give you a slight gain in performance in theory but you will never notice it from behind the wheel.
Had this mod on my car for a few years now, best thing I have ever done to it. Honestly, it sounds wonderful with the valves fully open all the time.
Mikefish tried out loads of exhausts on his RS4 over the years when he had it and this was the setup he finally settled on.
Coffey555 - whenu say valvues fully open, are you refering to the ones in the backbox...? Ive done that mod, and off to get the centre res deletes done...just wanna check thats it. 😁
coffey555
Post by coffey555 » Thu Sep 03, 2020 12:24 pm
Yes, the valves in the back boxes. It will sound epic with the centre res delete and the roof down!
Misano Red RS4 B7 Avant
Adymars
Post by Adymars » Thu Sep 03, 2020 12:28 pm
I had mine done on Tuesday. Sounds wicked now .
Fatneck73
Post by Fatneck73 » Thu Sep 03, 2020 12:52 pm
Excellent. Ta. I actually did this on my last 4...and it was gooooood. Wanted to check id understood for sure tho.
Im told theres also a flap in the manifold??? Can / should that Be ‘opened’?
coffey555
Post by coffey555 » Thu Sep 03, 2020 2:37 pm
There are many flaps in the manifold but they are there to improve low down torque. They can be removed to increase BHP and in some cases, to avoid falling out and destroying the engine.
Fatneck73
Post by Fatneck73 » Thu Sep 03, 2020 7:00 pm
Im not after BHP...prefer Torque...so i guess i leave well alone.
Cheers for the advice...again.
coffey555
Post by coffey555 » Thu Sep 03, 2020 10:17 pm
Same here, I like how flexible the engine is and the noise at low rpm in a high gear.
No worries, nice to see a bit of activity on here.
Adymars
Post by Adymars » Thu Sep 03, 2020 10:41 pm
Fatneck73 wrote:Im not after BHP...prefer Torque...so i guess i leave well alone.
I didn't do it for performance. More preventative. I had heard such stories about bolts coming undone I wanted a failsafe solution.
Grandadg90
Post by Grandadg90 » Fri Sep 04, 2020 6:38 pm
Ady i think you have gone the long way round with the manifold. When I did mine, I nudged the caps out with a long bolt by tapping with a hammer. Once flaps removed, i locate the caps back in place. So when I deflated, it cost just the loctite.
Exhaust wise, res delete, remove you aux radiator and fit an air pipe straight to the air box, from where the aux rad was. Induction noise is greatly increased and sounds awesome. Again the cost for that was the pipe. But its a bumper off job.
Hope that helps.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
Grandadg90
Post by Grandadg90 » Fri Sep 04, 2020 6:40 pm
Just catching up with the thread, seems that you aresorted now.
Adymars
Post by Adymars » Fri Sep 04, 2020 6:41 pm
I originally did it like that but one of the caps came loose and I <beep> myself so then went the failsafe way.
Users browsing this forum: Burty, Majestic-12 [Bot] and 107 guests
