Afternoon,
so my rear diff has given up, I've managed to source a good used one, was just wondering on oil type and how much does it take?
what is the best for a modified car?
mine is running 907ps 1200nm, so I assume I should use something high performance?
cheers Pete.
Rear Diff
Re: Rear Diff
Hi Pete - I used Motul 300 in my 900+ car, alongside a few other Stage 2 owners. It takes about 1.25L to fill but most importantly -
make sure you remove the top mounted fill plug BEFORE you remove the lower mounted drain plug and drain the old oil out, just to make sure you can actually refill it afterwards.
Re: Rear Diff
thanks Ian!IanH755 wrote: ↑Sat Jul 25, 2020 1:19 pmHi Pete - I used Motul 300 in my 900+ car, alongside a few other Stage 2 owners. It takes about 1.25L to fill but most importantly -
I will probably do the oil before I change the Diff over.
Is the fill plug on the side, and do I fill until it comes out?
cheers.
C6 RS6 Plus MRC 955ps 1220nms
Re: Rear Diff
Yes the fill is on the Right side and Yes fill to spill.
Users browsing this forum: Limited100 and 68 guests
