Rear Diff
5.0 V10 50v biturbo - 571 bhp
pete2144
Rear Diff
Post by pete2144 » Sat Jul 25, 2020 12:38 pm
Afternoon,
so my rear diff has given up, I've managed to source a good used one, was just wondering on oil type and how much does it take?
what is the best for a modified car?
mine is running 907ps 1200nm, so I assume I should use something high performance?
cheers Pete.
C6 RS6 Plus MRC 955ps 1220nms
IanH755
Re: Rear Diff
Post by IanH755 » Sat Jul 25, 2020 1:19 pm
Hi Pete - I used Motul 300 in my 900+ car, alongside a few other Stage 2 owners. It takes about 1.25L to fill but most importantly -
make sure you remove the top mounted fill plug BEFORE you remove the lower mounted drain plug and drain the old oil out, just to make sure you can actually refill it afterwards.
pete2144
Re: Rear Diff
Post by pete2144 » Sat Jul 25, 2020 1:40 pm
thanks Ian!
I will probably do the oil before I change the Diff over.
Is the fill plug on the side, and do I fill until it comes out?
cheers.
IanH755
Re: Rear Diff
Post by IanH755 » Sun Jul 26, 2020 9:32 am
cheers.
Yes the fill is on the Right side and Yes fill to spill.
pete2144
Re: Rear Diff
Post by pete2144 » Sun Jul 26, 2020 1:11 pm
cheers.
Thanks Ian...
