Fuel Pump Bracket
simonpoulton
Fuel Pump Bracket
Post by simonpoulton » Sun Jul 19, 2020 6:50 pm
Hi guys,
I'm trying to get my fuel pump off (the one outside of the tank) and the clamp bolt is just spinning. I can't get a mirror let along a socket round the other side to stop it and I really don't want to start cutting so close to tank and brake line.
Anyone know the trick to this? Bolt in question:
Simon
Past: R56 Mini Cooper S
Classik
Re: Fuel Pump Bracket
Post by Classik » Sun Jul 19, 2020 10:20 pm
On the other side there's a square bolt that is not secured which explains the trouble.. There could be other suggestions but the trick for me was to insert a large screwdriver behind the screw where both halves of the clamp meet so that the offending square bolt is pressed (hence secured) against the clamp, which should be enough to unscrew completely.
Sorry for bad English, I hope the above makes sense, but I can confirm it works ;)
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
simonpoulton
Post by simonpoulton » Mon Jul 20, 2020 7:12 am
Thanks for that Classik - I will have another go at it today!
Mɐʇʇ
Post by Mɐʇʇ » Mon Jul 20, 2020 11:13 am
Worst case, drill it rather than cut/grind. No sparks etc
Users browsing this forum: Majestic-12 [Bot], Shoppinit, srichards and 118 guests
