Aftermarket rear lights - different style to OEM
Anyone found any good aftermarket rear lights? I was looking for something to replace the slightly crazed inner rear lights and thought I'd see if there were any fresher designs. I found these . . . Which are a different style all together and more modern.
https://7-lights.de/led-rueckleuchten-a ... glas?c=116
and was wondering if anyone had any dealings with them or knew of the quality. They aren't particularly cheap by any means so I'm thinking they might be ok.
Re: Aftermarket rear lights
I got ones from europarts £100 each this was last year genuine VALCO ones thats who supplies Audi
Do the new lights have the same connectors as the old lights?
Nick
Nick
I've just fitted all new facelift rear lights to my avant (the inner ones where crazed) from autodoc.
Only £368 for valeo items, and the connectors were the same.
2006 RS4 Avant, Sprint blue, Buckets, Carbon trim, black optics, MRC stage 2 and Milltek non res valve'd. SOLD
2008 RS6 Avant, Sepang Blue, APR stage 1
I always wonder why the inner ones fade over time (and not outer or both at the same time)?
And it mainly affects estate C6's (and not saloons).
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
- H&R ARBs
I'd love to know why too!
I've got a C6 Allroad and a C6 RS6 so I've got to replace 4 at some point!
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
The fading is actually an optical effect from a myriad of micro cracks in the clear layer over the coloured part of the lens. I tried polishing my inners which lasted a couple of months - I then did it again and put a light smoke wrap on them. They didn't appear to fade after that but at night the micro cracking on the interior face was really visible. In the end I used it as an excuse to fit face lift lights when ECP were running one of their big discounts.
It is strange that only the inners fade. I was going to just replace them but then I started looking for other options. It's a shame that they didn't face-lift the shape of the rear lights on the Avant as I feel they date the car quite a lot. The ones in the link aren't particularly cheap at around £400 for a set. But I'm not sure if they will be a direct fit, include fog lights, not throw errors etc.
They also do headlights which incorporate the indicators into the daytime running light with the dynamic sweep. Again these might be left hand drive so that could be an issue.
Re: Aftermarket rear lights - different style to OEM
Doug_RS6 wrote: ↑Thu Jun 25, 2020 4:05 amAnyone found any good aftermarket rear lights? I was looking for something to replace the slightly crazed inner rear lights and thought I'd see if there were any fresher designs. I found these . . . Which are a different style all together and more modern.
Do it. I have them on mine and they’re awesome. Easy to fit as they “bolt on”
Are they suitable for left and right hand drive?Ranger4130 wrote: ↑Thu Jul 09, 2020 11:08 pmDoug_RS6 wrote: ↑Thu Jun 25, 2020 4:05 amAnyone found any good aftermarket rear lights? I was looking for something to replace the slightly crazed inner rear lights and thought I'd see if there were any fresher designs. I found these . . . Which are a different style all together and more modern.
Did it. I have them on mine and they’re awesome. Easy to fit as they “bolt on”
Really?Doug_RS6 wrote: ↑Mon Jul 13, 2020 1:54 pmAre they suitable for left and right hand drive?Ranger4130 wrote: ↑Thu Jul 09, 2020 11:08 pmDoug_RS6 wrote: ↑Thu Jun 25, 2020 4:05 amAnyone found any good aftermarket rear lights? I was looking for something to replace the slightly crazed inner rear lights and thought I'd see if there were any fresher designs. I found these . . . Which are a different style all together and more modern.
Yes really. I was actually meaning the front ones mentioned earlier from same supplier. But the rear could be different spec depending on market. Fog lights, etc. Thanks for your helpful pedantry though.Ranger4130 wrote: ↑Mon Jul 13, 2020 11:16 pmReally?Doug_RS6 wrote: ↑Mon Jul 13, 2020 1:54 pmAre they suitable for left and right hand drive?Ranger4130 wrote: ↑Thu Jul 09, 2020 11:08 pm
Haha, I thought you were referring to the rear ones being handedDoug_RS6 wrote: ↑Tue Jul 14, 2020 7:37 pmYes really. I was actually meaning the front ones mentioned earlier from same supplier. But the rear could be different spec depending on market. Fog lights, etc. Thanks for your helpful pedantry though.
I haven’t got the front ones only the rears which are a great improvement over the stock items and come recommended.
Users browsing this forum: No registered users and 200 guests
