Instrument Cluster
steve2003rs6
Re: Instrument Cluster
Post by steve2003rs6 » Sun Jun 28, 2020 3:00 pm
When I took the cluster out. Did notice a light at the bottom about 12 inches below where the cluster sits ?
Don’t know what that is.
ChrisA
Post by ChrisA » Sun Jun 28, 2020 3:04 pm
Oh yes, I see.
Still it’s got to be worth checking the connections to the back of the cluster.
With your old cluster can you check the lamp on the bench? If that’s working then it would prove it’s a problem with you car rather than a coincidence that two lamps have failed.
As you know I know very little about these cars so any thing I say should be taken with a pinch of salt.
steve2003rs6
Post by steve2003rs6 » Sun Jun 28, 2020 3:07 pm
Because of the problem I had with the spare cluster.
I asked cartronix to check the backlights on my original.
They told me they were all ok.
Post by Shoppinit » Sun Jun 28, 2020 3:31 pm
Sounds like a wiring problem between the dimmer and the cluster. Didn’t think there was a fuse but I’ll check.
steve2003rs6
Post by steve2003rs6 » Sun Jun 28, 2020 3:43 pm
Thanks Shop. As far as I am aware the only connections at the back of the cluster are the three plugs. grey green and blue.
Is there a separate wire for the dimmer ?
Very much appreciate your expertise.
steve2003rs6
Post by steve2003rs6 » Sun Jun 28, 2020 5:03 pm
This is a new error since replacing the original cluster with new dis screen.
Post by Shoppinit » Sun Jun 28, 2020 5:50 pm
They’re all intermittent and probably due to unplugging the cluster. Clear them and see if any come back.
steve2003rs6
Post by steve2003rs6 » Sun Jun 28, 2020 6:04 pm
Cheers Shop. Will do and report back
Post by Shoppinit » Sun Jun 28, 2020 6:09 pm
Had a quick look and the dashboard light settings seems to go straight from the headlight switch to the cluster via the green 32pin connector on the dashpod.
Have you still got the old headlight switch?
steve2003rs6
Post by steve2003rs6 » Sun Jun 28, 2020 6:26 pm
Hi Shop. You were right again. Ran autoscan and all previous faults disappeared. Didn’t need to delete them. They were not there and no faults found was recorded.
Still have no backlights though.
Bit of a pain after all we have been through.
steve2003rs6
Post by steve2003rs6 » Sun Jun 28, 2020 6:28 pm
Yes I kept the old headlight switch.
Still in the box that the new one came in.
Switch them over and see what happens and report back.
steve2003rs6
Post by steve2003rs6 » Sun Jun 28, 2020 6:45 pm
Just changed the switches over. Still no luck.
No backlights. Bugger.
I presume the backlighting is via led,s inside the cluster ?
Thanks buddy.
Looking like I need a new cable ? If you can still get them.
Or call in a auto electrician.
Love/hate relationship with the car at the moment.
Will love her again in the morning lol.
Post by Shoppinit » Sun Jun 28, 2020 7:45 pm
I’ll have another look at the wiring when I get a chance.
In the meantime, have you checked all the fuses?
Post by chunky79 » Sun Jun 28, 2020 7:46 pm
I'd be tempted to whip the cluster back out Steve and check the wires in the connector plug as mentioned above.
You have the manuals Steve, have a quick look at the wiring diagram to see which wire goes where :thumbs:
steve2003rs6
Post by steve2003rs6 » Sun Jun 28, 2020 8:03 pm
Dunc. I have the manuals ! Done nothing but read manuals.
Ps they are in lovely condition by the way. Did you ever use them. Not a single mark or oily fingerprint.
All the fuses I have looked at also effect something else. Climate control for example.
Everything is ok apart from backlights on cluster.
Both of them.
Will resume diagnostics tomorrow.
Really pleased with your sale. Hope you got what you wanted buddy.
