Urgent suspension help
Re: Urgent suspension help
Post by Shoppinit » Thu Jun 04, 2020 2:45 pm
That's more like it.
Astrosquirrel
Post by Astrosquirrel » Thu Jun 04, 2020 6:46 pm
Human Joist wrote:They look good.
I’ve just collected these springs. They are off a plus so will sit a bit lower as well. Chuffed with this. Will get them fitted tomorrow
Those look great. Glad you sorted it Image
Sent from my SM-N975F using Tapatalk
Human Joist
Post by Human Joist » Thu Jun 04, 2020 8:21 pm
Cheers. Got the rear assembled and fitted now will do the fronts tomorrow. Just hoping that sod of a multi link suspension bolt at the top plays ball 🤣 I’ve had enough set backs with the suspension
MalcolmSu
Post by MalcolmSu » Thu Jun 04, 2020 10:22 pm
ChrisA wrote:
Thu Jun 04, 2020 2:00 pm
Can I have second dibs on these if you find all four please.
Sorry, been through my garage and can only find the one (rear?) set.
IchBautAuto
Post by IchBautAuto » Fri Jun 05, 2020 12:37 am
Interesting. The colour code on your springs is the same as mine. Would that not mean they are the same??? They do look very fresh though so great find.
Post by Shoppinit » Fri Jun 05, 2020 9:16 am
Cool. I'm not convinced they are plus springs, though, but the parts catalogue is pretty opaque on the colour codes, so hard to be sure.
Mɐʇʇ
Post by Mɐʇʇ » Fri Jun 05, 2020 9:53 am
You absolutely don’t need to undo it.
Cheers. Got the rear assembled and fitted now will do the fronts tomorrow. Just hoping that sod of a multi link suspension bolt at the top plays ball 🤣 I’ve had enough set backs with the suspension 96EAD725-E94D-4E01-91BA-6D37987EB7ED.jpeg
Human Joist
Post by Human Joist » Fri Jun 05, 2020 4:48 pm
Ok. I ended up undoing that and the two 13mm under the bonnet each side to drop it down. They both undid and slid out no issues. The back up plan was to leave them alone if they didn’t play ball.
All done now and just getting tracked up
Post by Shoppinit » Sat Jun 06, 2020 6:08 pm
These ones? (green)
Human Joist
Post by Human Joist » Sun Jun 07, 2020 1:44 pm
These ones? (green)
Yes mate. Your guide wasn’t it. Went really well. Little nuts but rather rusty.
On a side note I’ve noticed a little knock today so will check everything tomorrow. I think now that the suspension actually moves it will highlight the odd worn part.
Got it all tracked up yesterday. Went well apart from the one rear right tracking bolt innermost with the multispline thread that was stuck fast. They didn’t want to snap it and suggest the bush will be swollen and need the bolt curing out
Post by Shoppinit » Sun Jun 07, 2020 3:13 pm
Check the steering rack bolts. They have a tendency to come loose.
I've got a knocking / rattling from the front left of the Mitsubishi. Sigh. I hate suspension problems.
Human Joist
Post by Human Joist » Mon Jun 08, 2020 1:58 pm
This knock is from the rear. Maybe exhaust, will have a hunt. I’d rather have suspension issues than random knock hunting 🤣
Mɐʇʇ
Post by Mɐʇʇ » Mon Jun 08, 2020 3:22 pm
A relief. :beerchug:
Human Joist
Post by Human Joist » Tue Jun 09, 2020 6:31 pm
Cheers. Overall it went well. The seized bolt for the rear bush will be cut out next year and I will renew the lot. Maybe polybush them.
I’ve noticed a little knock on the front. Which I reckon is the drop links. The front right one looked a little older than the front left. Is it worth getting some drive on ramps so I can check it and the rest under load ??
The only issue I have noticed I’m not sure about is the rear right corner seems to sit lower than the rest. Has anyone else had similar issues on these ?
Human Joist
Post by Human Joist » Wed Jun 10, 2020 6:28 pm
So this is now after two days
This is just after it was fitted. Seems the suspension has settled a bit. But almost a bit more at the rear
Users browsing this forum: Bing [Bot] and 130 guests
