When I had this, a week on the trickle charger cleared the fault.
When mine threw an error when the battery was a little low it said it was the front left level sensor but the DRC cars don't have a front left sensor, only air suspension cars have them on all 4 corners. DRC only has them on front right and rear left I think. I might have got that the wrong way round but I recall stripping half the front of the car away trying to find a sensor that doesn't exist. When I looked on the other side I could see it without stripping anything off.bigbaz1974 wrote: ↑Tue Jun 09, 2020 12:00 pmI've had this twice on my rear shocks, it's a ride height sensor. Had both DRC shocks replaced under warranty. My car is also running KW springs but did cause a problem with the warranty
What was the problem that your drc broke?
I had my car in 2 separate times the rear driver side failed then 6 months later the rear passenger side. Both times audi dundee said it was the level sensor. Wasn't aware they didn't have that on all corners. They were replaced under warranty anywayMikeFish wrote: ↑Tue Jun 09, 2020 12:40 pmWhen mine threw an error when the battery was a little low it said it was the front left level sensor but the DRC cars don't have a front left sensor, only air suspension cars have them on all 4 corners. DRC only has them on front right and rear left I think. I might have got that the wrong way round but I recall stripping half the front of the car away trying to find a sensor that doesn't exist. When I looked on the other side I could see it without stripping anything off.bigbaz1974 wrote: ↑Tue Jun 09, 2020 12:00 pmI've had this twice on my rear shocks, it's a ride height sensor. Had both DRC shocks replaced under warranty. My car is also running KW springs but did cause a problem with the warranty
Yup, caused by the ‘lack of oil’ that had perished as a result of a fault.LRB23 wrote:I’ve just got mine back after 4 months of being stuck at Audi Hatfield with a DRC issue. All four shocks were replaced under warranty/factory good will. According to Audi it’s a known issue with the C7 DRC.
Mine started with a knocking/clunking coming from the rear left and drivers side.
