Car won’t start. Help. Ideas needed
pule333
Post by pule333 » Sun May 10, 2020 12:26 pm
Hi Guys. Hope everyone is well!
Been having issue with my B7 lately. On occasion it would not engage the starter. But after few tries be ok. Was only intermittent once a month or so. But last week it was terminal. Started on the way to shops fine. But wouldn’t start coming back. Had to push start down the hill after wife came to rescue with tow rope. The bugger won’t start now at all! Just does the clicking sound. I suspect it’s the Starter motor gone. Any other ideas?
https://youtu.be/6mc7EKBgMPo
RS4 B7 aka Vinnie
mikep99
Re: Car won’t start. Help. Ideas needed
Post by mikep99 » Sun May 10, 2020 1:16 pm
Does the starter click when it doesn't start? or just the relays that you can hear inside the car?
If the starter clicks, The relays etc should be ok as its getting the signal to start.
Another thing to check is the following connection next to the positive terminal under the bonnet:
This is the wire that has 12v put through it to trigger the starter motor. Check which side goes to the ecu if you're going to measure it.
If you get power through this and the car wont start, this will also confirm your relays etc are ok.
I have a similar issue as yours and I've spent a lot of time looking into it.
Mine doesn't start only when the engine is at operating temp after a run. Then, after 40 mins ish it'll start fine.
I'll look for a dodgy earth next between the starter and the chassis.
Mike
mikep99
Post by mikep99 » Sun May 10, 2020 1:37 pm
These may help if you're looking to troubleshoot before getting a new starter..
starter.pdf
(149.52 KiB) Downloaded 116 times
QuRace
Post by QuRace » Sun May 10, 2020 8:19 pm
Apologies for being /OT, but where are the attached wiring diagrams from? They certainly don't look like the "official" VAG "Current Track" diagrams...
mikep99
Post by mikep99 » Sun May 10, 2020 8:27 pm
They're from a repair manual that was posted on here a while back.
QuRace
Post by QuRace » Sun May 10, 2020 9:06 pm
Thx. And I had already downloaded that then... I must be getting old...
Nige_RS4
Post by Nige_RS4 » Mon May 11, 2020 10:34 am
Have you checked your battery voltage / condition. Low batt voltage will cut the starter circuit to protect the electronics as the starter draws a sh1t load of juice, and it can make the click noise you hear. I've seen tons of posts on other forums about non-starting cars during the UK lock-down. Batteries are failing due to non-use, or the charge is just too low.
HTH
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
pule333
Post by pule333 » Mon May 11, 2020 10:39 am
Nige_RS4 wrote:Have you checked your battery voltage / condition. Low batt voltage will cut the starter circuit to protect the electronics as the starter draws a sh1t load of juice, and it can make the click noise you hear. I've seen tons of posts on other forums about non-starting cars during the UK lock-down. Batteries are failing due to non-use, or the charge is just too low.
HTH
It’s on trickle charge when not in use. It started fine when I went to shops.
RS4 B7 aka Vinnie
Nige_RS4
Post by Nige_RS4 » Mon May 11, 2020 11:28 am
Charging a duff battery won't fix it.
How old is the battery?
Does your trickle charger have a 'float' mode once it's charged the battery, as over-charging is bad for lead acid batteries?
I've been here myself in the last 2 weeks - my son's car would crank no problem but wouldn't start. Took the battery out and charged it overnight and hey presto, fired up first time.
Personally, I'd charge it (not trickle) overnight and then take it to a battery place to test.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
pule333
Post by pule333 » Mon May 11, 2020 11:38 am
6 months old. It’s always on trickle.
RS4 B7 aka Vinnie
Nige_RS4
Post by Nige_RS4 » Mon May 11, 2020 1:29 pm
If you're confident that it isn't the battery then can you not test the clutch switch by bypassing it i.e. connect the 2 terminals together. That would eliminate that part (even though it's been replaced). I couldn't hear the clicking in the video btw? Sounds like your issue is more electrical than mechanical.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
pule333
Post by pule333 » Mon May 11, 2020 2:21 pm
Nige_RS4 wrote:If you're confident that it isn't the battery then can you not test the clutch switch by bypassing it i.e. connect the 2 terminals together. That would eliminate that part (even though it's been replaced). I couldn't hear the clicking in the video btw? Sounds like your issue is more electrical than mechanical.
Oh it clicking alright lol. Can post video here.
RS4 B7 aka Vinnie
GG441
Location: Wallstrasse 28, Hessen, 35321, Laubach, Germany
Post by GG441 » Tue May 12, 2020 2:53 am
Few days behind i faced the smoke problem. I called a technician it charged me €55.
maars
Post by maars » Tue May 12, 2020 9:43 am
Have you tried jump starting it off another car/battery to eliminate the RS4's battery?
Daytona RS4 Avant - black optics/decat downpipes/H-pipe/KW springs - featured on the 2012 Audi stand at the Goodwood FoS
pule333
Post by pule333 » Tue May 12, 2020 9:44 am
maars wrote:Have you tried jump starting it off another car/battery to eliminate the RS4's battery?
Yes
RS4 B7 aka Vinnie
Users browsing this forum: Google Adsense [Bot] and 88 guests
