Thanks in advance for any advice
Always closed in Comfort and open in Dynamic even after an ignition cycle. You can toggle open / shut though in any mode by tapping Sport button.Avantgarde wrote:I’m getting my RS4 in a month or two. I’m curious as to how this module changes the original function of the valves? Aren’t the valves closed in Comfort and open when in Dynamic originally? Thanks for sharing.
What is the valve behaviour without the Cete module?Terminator_X wrote: ↑Sat Aug 29, 2020 5:47 pmAlways closed in Comfort and open in Dynamic even after an ignition cycle. You can toggle open / shut though in any mode by tapping Sport button.Avantgarde wrote:I’m getting my RS4 in a month or two. I’m curious as to how this module changes the original function of the valves? Aren’t the valves closed in Comfort and open when in Dynamic originally? Thanks for sharing.
TX.
Sent from my BBB100-2 using Tapatalk
Ah sorry I misread your post! From the factory the left valve is open at startup and idle; it then closes as you pull away. In Comfort the valves stay shut. In Dynamic both open at about 4k revs. Every ignition cycle though the car defaults to Comfort even if you leave the car in Dynamic when you turn it off.Avantgarde wrote:What is the valve behaviour without the Cete module?Terminator_X wrote: ↑Sat Aug 29, 2020 5:47 pmAlways closed in Comfort and open in Dynamic even after an ignition cycle. You can toggle open / shut though in any mode by tapping Sport button.Avantgarde wrote:I’m getting my RS4 in a month or two. I’m curious as to how this module changes the original function of the valves? Aren’t the valves closed in Comfort and open when in Dynamic originally? Thanks for sharing.
TX.
Imho they did it to avoid anti social noise in day to day driving e.g. unlikely to go above 4k unless booting it. Less of an issue in the RS4 vs say the RS3 which was absolutely nuts with the valves open from idle!Avantgarde wrote:Is there drone below 4k rpm if you use the Cete module and set on always Open? Just wondering if Audi did that so as to avoid unwanted or unflattering sounds between 1k to 4k revs.
Users browsing this forum: No registered users and 10 guests
