Air Con Advice
WRS4
Air Con Advice
Post by WRS4 » Fri Apr 17, 2020 6:44 pm
Now its a bit warmer ive noticed my fan is not as cool as it was when I purchased the car, even now im still learning things about the car even after 2 years lol.
Anyway I have only just found out that Air con is on only when the econ button is NOT lit up, I cant actually get this light to go off, from what I gather this can be a few issues but the more common one is that it needs a re charge / refrigeration added.
Is this something I can do myself ? and if so what do I need to buy / tools ?
Sprint Blue RS4 - 20" X 10J 3DSM Wheels - Carbon Front Splitter - Carbon Rear Diffuser - H & R Anti Roll Bars - Bilstein Adjustable Shocks - Milltek Exhaust System - De Catted - Valve Removed - MRC Stage 2 Re-Map - 480 bhp
Re: Air Con Advice
Post by chunky79 » Fri Apr 17, 2020 7:38 pm
Specialist job, you obviously have an issue with it. Kwick fit do it cheap so I believe. I have all the kit to do it in my work van.
WRS4
Re: Air Con Advice
Post by WRS4 » Fri Apr 17, 2020 7:40 pm
ok will give them a call tomorrow, shame your too far away but cheers for the advice
Re: Air Con Advice
Post by chunky79 » Fri Apr 17, 2020 7:42 pm
Looks like the issue happened to you last year, going by your posts about the steam coming from the vents.
WRS4
Re: Air Con Advice
Post by WRS4 » Fri Apr 17, 2020 9:46 pm
that only ever happened twice and has never done it again so thought nothing of it, but maybe your right...if that is the case do you know why that would have happened? as I say its never done it again I forgot all about that especially as ive not used ac since then as its been cooler
Heardy
Re: Air Con Advice
Post by Heardy » Wed Apr 29, 2020 9:39 pm
Usual reason for econ button not going off is either low refrigerant Or possible issue with pressure switch. If you have access to VCDS or similar that would help
2007 B7 RS4
Previously
C5 RS6 Saloon Avus, Phase 2 Viper Remap, Wagners, Full Milltek, Hotchkis Arb's, 390mm C6 Brake's, H&R Coilovers
coffey555
Re: Air Con Advice
Post by coffey555 » Wed Apr 29, 2020 11:36 pm
If you have a leak in the system it can draw in air, this can trigger the pressure switch as the system is overpressuried. Which could be why the econ light stays on.
My one had a tiny leak under a metal bracket, only found by injecting a uv dye into the system.
Either leave a working system on all year round or don't bother fixing it.
Misano Red RS4 B7 Avant
Re: Air Con Advice
Post by chunky79 » Thu Apr 30, 2020 5:45 am
Its a pressurised system, if you have a leak you won't draw in air and over pressurise it. If you have a leak, you'll lose all pressure.
Users browsing this forum: Google [Bot] and 91 guests
