£1000 discs!?
airtite
Re: £1000 discs!?
Post by airtite » Tue Mar 17, 2020 6:26 pm
Quattrojan wrote:
Tue Mar 17, 2020 12:54 pm
s8quattro1979rs wrote:
Thu Mar 12, 2020 5:47 pm
£150 each side for the fronts, on a german website. i posted it in the general section a couple of days ago, oe quality zimmerman too.
Linky Linky please :)
Ditto...
bilko1
Re: £1000 discs!?
Post by bilko1 » Tue Mar 17, 2020 10:15 pm
airtite
Re: £1000 discs!?
Post by airtite » Wed Mar 18, 2020 10:58 am
those arent cross drilled?
Mark-RS
Re: £1000 discs!?
Post by Mark-RS » Wed Mar 18, 2020 1:31 pm
Apparently those are prone to cracking. The drilled ones.... Although mine seem fine, although maybe somehow warped as I have judder. Not sure if that may have had anything to do will the drilled holes though.
And the grooved ones are apparently noisy.
Re: £1000 discs!?
Post by Shoppinit » Wed Mar 18, 2020 1:59 pm
Plain disks FTW.
Re: £1000 discs!?
Post by chunky79 » Wed Mar 18, 2020 2:11 pm
Plain disks FTW.
Have you got "j" hooks?
Re: £1000 discs!?
Post by Shoppinit » Wed Mar 18, 2020 2:21 pm
No. I've got drilled because I run C6 disks and they don't do plain ones.
Mark-RS
Re: £1000 discs!?
Post by Mark-RS » Wed Mar 18, 2020 4:59 pm
Out of interest what is required for a C6 set up ? Calipers also ?
Re: £1000 discs!?
Post by Shoppinit » Wed Mar 18, 2020 5:01 pm
It's a faff. I wouldn't do it again.
If you want to take advantage of the bigger disk surface then you need calipers. You also need to bring the disks out 6mm IIRC. So they don't foul on the suspension arm. So that means you need a hub extension. It's a pain, basically.
Re: £1000 discs!?
Post by chunky79 » Wed Mar 18, 2020 6:16 pm
Ah, couldn't remember if you had the special set up as well. Take it you just did some of the donkey work for the mongs?
Re: £1000 discs!?
Post by Shoppinit » Wed Mar 18, 2020 7:24 pm
Yup. Seems like a long time ago now. Might have provided some dimensions of stuff. Can't remember. I thought you had gone for some of the J-hook disks.
Re: £1000 discs!?
Post by chunky79 » Wed Mar 18, 2020 7:59 pm
Nah, I've got the drilled "plus" discs. I couldn't justify the money them pair paid for their brakes at the time.
bilko1
Re: £1000 discs!?
Post by bilko1 » Sat Mar 21, 2020 12:23 am
Could go with these cheaper than Audi and future replacements would be alot cheaper. https://www.ebay.co.uk/itm/Audi-RS6-C5- ... .l4275.c10
s8quattro1979rs
Re: £1000 discs!?
Post by s8quattro1979rs » Sat Mar 28, 2020 9:54 am
Just for info, I managed to buy OE quality Zimmerman front discs (365mm) for £147 each side.
I checked lots of places (GSF/ECP/online) before ordering and these were the best I could find
Q-Parts24 GmbH & Co. KG on ebat Germany, but they can be ordered on the UK site too.
They arrived about 5-7 days after I ordered them.
Link to one side:
https://www.ebay.co.uk/itm/Bremsscheibe ... SwX6peIqVb
Matt58
Re: £1000 discs!?
Post by Matt58 » Sat Mar 28, 2020 11:03 am
I changed all for discs for Zimmerman.
I used winparts, very reasonable, good service, took a little time to get here, but worth it for the price. I used them for rear calipers as well.
