Running without TPMS
dools225
Post by dools225 » Fri Feb 07, 2020 8:58 pm
Is anyone successfully running error free with no TPMS?
Just had my wheels refurbed so decided I would leave the sensors out to avoid any problems down the line with failures.
I have coded them out through VCDS so not getting any of the visual errors or dash like a christmas tree, however after about 20 mins of driving this morning the EML came on! Just scanned using VCDS and it is 01521 which is no signal/communication to sensors.
Is there any way to stop this coming on?
Pic attached of shiny wheel and freshly refurbed calipers because why not :mrgreen:
mikep99
Re: Running without TPMS
Post by mikep99 » Fri Feb 07, 2020 9:04 pm
what did you do to code them out, it should be:
Select -> 17-Instruments -> Adaptation -> Channel 61.
Subtract 512 from whatever value you find there.
You'll continue to get errors when you do a scan but the EML shouldnt come on.
Mike
dools225
Post by dools225 » Fri Feb 07, 2020 9:09 pm
Mike
Cheers for the reply mate, yep did exactly that.
Was all good at first but then the EML came on!
mikep99
Post by mikep99 » Fri Feb 07, 2020 9:13 pm
hmmm, not sure then.
No other messages in the scan?
Mike
dools225
Post by dools225 » Fri Feb 07, 2020 9:16 pm
Mike
No pal.
Thinking about it now, it’s not actually a pressure issue fault, its a communication fault. So i’ll see if keeping the sensors in the boot keeps it happy!
Imagefree img
mikep99
Post by mikep99 » Fri Feb 07, 2020 9:20 pm
try clearing it, see if it comes back...
I get the same in my scans but no MIL...
Mike
dools225
Post by dools225 » Fri Feb 07, 2020 9:33 pm
Mike
Have cleared it and its happy at the moment, will see what happens on the way to work in the morning. Cheers for your help mate 👍🏻
Out of curiosity are your sensors still fitted?
mikep99
Post by mikep99 » Fri Feb 07, 2020 9:40 pm
yep, but one of them needs replacing so I get this message:
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Mike
DavidRS4
Post by DavidRS4 » Sat Feb 08, 2020 7:48 am
Removed my sensors years ago. Did the subtraction on VCDS. No problems at all.
dools225
Post by dools225 » Sat Feb 08, 2020 8:54 am
Double checked Channel 61 and the figure is still on my subtracted value of 3331.
No issues on the drive to work this morning anyway so hopefully just a bit of a brain fart by the car after the change.
Thanks for the input :beerchug:
lushman
Post by lushman » Mon Feb 10, 2020 2:46 pm
Just removed TPMS from mine and followed the VCDS instructions and all good. no lights :)
2006 B7 RS4 Avant Sprint Blue & Black Optics
2000 Avus Silver B5 RS4 - Gone
