Hope everyone's very well. Random one, My coolant light has been saying "turn engine off check coolant" when this happens it is about a inch below minimum requirment. And again random when it decides to do it. The fix is - Turn the car back on give it some revs. The coolant fills back up to the prefect mark. Go figure! (I assume pressure related at this point) as also when I take the fill cap off again the level increases.
Anyway now the heat in the car cockpit is at best Luke warm,sometimes cold .. I have assumed this is linked. The car was dropping some coolant in December very little and Audi told me they tested it but can not find a leak or fault
The 2 release values in the media attached could some kind person explain to me what there job is. Obviously under pressed on both lines labed 1 & 2 .
