S5 9x20 fitting advice
maars
Post by maars » Thu Jan 09, 2020 11:51 pm
When fitting the OEM S5 9x20ET29 wheels on the B7 RS4 what size spacers are required?
Do you need longer wheel bolts, and if so, what size?
Thank you! :thumbs:
Daytona
Re: S5 9x20 fitting advice
Post by Daytona » Fri Jan 10, 2020 8:31 am
It’s around 4mm to clear the calipers but as hubcentric ones aren’t available that thin I used 8mm with no issues and bought 8mm longer bolts.
Spigots are req too
maars
Post by maars » Fri Jan 10, 2020 8:34 am
Thanks Daytona.
Did you use 255 or 265 tyres? Any rubbing issues?
Where did you get the spacers/bolts from?
Daytona
Post by Daytona » Fri Jan 10, 2020 12:36 pm
I’m currently on 255’s but the 265’s I had on before were ok too, suppose it all depends how low the car is.
Pretty sure I got them on eBay, night have been an German seller. I’m thinking of selling the spacers and spigots, if you’re interested give me a pm
Quango86
Post by Quango86 » Fri Jan 10, 2020 12:38 pm
I'm interested in the spacers also if you want to drop me a pm I'm on the standard 19s
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
RS4SA
Post by RS4SA » Sat Jan 11, 2020 6:13 am
H&R make hub centric spacers with the correct hub size which allow for the hub size difference between the RS4 and S5. That remove the need for separate spigots!
Covkiller
Post by Covkiller » Wed Feb 12, 2020 8:41 pm
You wont' get 4mm hub centric spacers.
RS4SA
Post by RS4SA » Tue Feb 25, 2020 6:02 pm
Covkiller wrote:You wont' get 4mm hub centric spacers.
Correct, only from 8mm upwards!
Rick_RS4
Post by Rick_RS4 » Tue Feb 25, 2020 7:58 pm
Fitted with no spacers 255 30 tyres and pretty low
Currently forsale too
DavidRS4
Post by DavidRS4 » Tue Feb 25, 2020 9:55 pm
That looks amazing Rick!
Rick_RS4
Post by Rick_RS4 » Tue Feb 25, 2020 11:53 pm
:thumbs: thankyou. Changed a bit since then. Wheels, trim, brakes ha ha ,
Covkiller
Post by Covkiller » Mon Apr 27, 2020 9:46 pm
Post a recent photo then Rick.
maars did you get your 20's on ?
Users browsing this forum: Zyox and 46 guests
