VCDS - Carista
Re: VCDS - Carista
Just checked and a quick pull on the driver's door switch opens the boot, a long pull closes it with the alarm. Key does both too.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Re: VCDS - Carista
My car has no keyless option so I bet I can’t close boot by pressing key fob, and no app or carista device will do that as Mike sais, at least I can open my boot with remote key fob by far distance
Re: VCDS - Carista
I'd be surprised if no apps will do it, but not sure which can or can't. VCDS will definitely do it. I've used VCDS to change this on about 10 cars. My car didn't have keyless entry but I changed it so that it works from button and keyfob.
Note that the keyfob won't close the boot when the engine is on.
Re: VCDS - Carista
The beeps are correct when you are closing by other means than the boot button to warn anyone by the boot that it is closing that you might not have seen.
You can change it so that you don't need a long press to close the boot. I had it set so that only opening with the remote required a long press, everything else (including open and closing from the door button) only needed a short press.
Re: VCDS - Carista
Well if VCDS can do maybe carista can also, I just couldn’t find it where that option isMikeFish wrote: ↑Tue Jan 07, 2020 8:45 pmI'd be surprised if no apps will do it, but not sure which can or can't. VCDS will definitely do it. I've used VCDS to change this on about 10 cars. My car didn't have keyless entry but I changed it so that it works from button and keyfob.
Re: VCDS - Carista
What was the code for not needing the long press?MikeFish wrote: ↑Tue Jan 07, 2020 8:48 pmThe beeps are correct when you are closing by other means than the boot button to warn anyone by the boot that it is closing that you might not have seen.
Current
2016 RS6 C7.5 Performance Sepang
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
and loads of other shitbox's
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
Re: VCDS - Carista
You change the long press to 0 and the short press to 1. I'll have to dig out the byte and bit numbers later but I have posted the full instructions on this forum before if you want to search now.Sandy-m2 wrote: ↑Wed Jan 08, 2020 12:19 pmWhat was the code for not needing the long press?MikeFish wrote: ↑Tue Jan 07, 2020 8:48 pmThe beeps are correct when you are closing by other means than the boot button to warn anyone by the boot that it is closing that you might not have seen.
Re: VCDS - Carista
Thanks Mike
Found this so you probably dont need to repost it for me. I'll just try and work out how to do it next! lol
Ok, I've just read about someone with a facelift car with exactly the same issue as you ie both were already actives and this post helped them fix it and get it working:
Check that both tap and touch are not activated at the same time:
6D – Trunk electronics
Security access – 16 = 12345
Address 6D:4G9 959 107 A recoded (ADP-(4)-Activation using rear lid opening button in remote key-Tap function for closing) from not active to active
Address 6D:4G9 959 107 A recoded (ADP-(3)-Activation using rear lid opening button in remote key-Touch function for closing) from active to not active
Address 6D:4G9 959 107 A recoded (ADP-(4)-Activation using rear lid remote unlocking switch-Tap function for closing) from not active to active
Address 6D:4G9 959 107 A recoded (ADP-(3)-Activation using rear lid remote unlocking switch-Touch function for closing) from active to not active
This will result:
remote opening – long press - touch
remote closing – short press - tap
door closing – short press – tap
Touch = long press is set for opening to prevent accidentally opening the hatch.
Current
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
Re: VCDS - Carista
Just tried carista and got those boot options: so which one is for closing boot with remote key?
Re: VCDS - Carista
I think that's pretty much it. Essentially if you want the tap (i.e. short press) to do anything make that option active or if you want the touch (i.e. long press) to do anything make that option active. But don't have both active at the same time or won't work i.e. if you have rear lid opening button in remote key tap active and touch active then it won't work, you'll need to make the one you don't want to work not active.Sandy-m2 wrote: ↑Wed Jan 08, 2020 1:32 pmThanks Mike
This will result:
All the option you quoted above from my old post are repeated for the tap function for opening, touch function for opening etc too so there are twice as many options when you open it on VCDS but they work in exactly the same way as I just described but should already be set correctly as it's only the closing functions you are trying to change.
Re: VCDS - Carista
Are those options the current settings in your car (the yes and no part)? I ask because they look wrong from the factory setting to me.
This is my opinion on these settings;
open power trunk via remote (touch) set to yes
close power trunk via remote (touch) set to no
open power trunk via remote (tap) set to no
open power trunk via unlocking switch (tap) set to yes
close power trunk via unlocking switch (tap) set to yes
However, I'd expect to also see the following too:
open power trunk via unlocking switch (touch) set to no
close power trunk via unlocking switch (touch) set to no
Re: VCDS - Carista
Those pictures I took when I scanned my car, didn’t touch anything in there. P.s my car has no keyless optionMikeFish wrote: ↑Wed Jan 08, 2020 9:08 pmAre those options the current settings in your car (the yes and no part)? I ask because they look wrong from the factory setting to me.
Why I don’t see those options:?
Could it be because I don’t have keyless option?
Re: VCDS - Carista
This worked for me in ODB11 once i worked out that it was an Adaptation and not a long code, Just in case anyone else is trying!
Current
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
Re: VCDS - Carista
Hi all,
I bought Carista as it was so cheap and supposed to be good.
Can anyone recommend the best customisation's/tweaks you have done using this please?
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Re: VCDS - Carista
Things ive done:
Beep when lock
Rear lights on with DRL's
One touch boot close on key/door
drl's dim not off when indicating
Things i'm thinking about doing or would like to know how to do:
start stop button remembers the setting
windows continue to go up even if i open the door
VIM (i did this on my q7 but the rs6 doesn't seem to want to play video ever)
Economy mode
But i'm also looking for suggestions of things people have done that they have found beneficial....
Beep when lock
Economy mode
Current
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
2005 Smart Roadster
Previous
Audi Q7
VW Toareg
Toyota Supra Mkiv
