There are 3 x torx screws along the bottom, which I've undone, and that's as far as I've got....
Can anyone help?
Sent from my Pixel 3 XL using Tapatalk
Yes - think it's the same one .Quango86 wrote:Did you win this one on ebay? I thought about buying it aswell
Thanks Kenny - have removed the inlet plug and the 3 x screws so just keep pulling?Kenny147 wrote:Open the cooler door and at the back there may be the inlet plug from the A/C. Unscrew and remove that and the whole unit should slide out, if you’ve removed the 3 T8 screws.
You're a legend. Thanks mateKenny147 wrote:Forgot.....there are two clips about 4 cm in from each end at the top. You’ll probably need to “lift” the glove box shelf above the cooler, up a bit to get it out.
Thank you again for this. Just released the cooler by prying up the 'shelf' which would normally hold the CD changer and it came out very easily.Kenny147 wrote:Forgot.....there are two clips about 4 cm in from each end at the top. You’ll probably need to “lift” the glove box shelf above the cooler, up a bit to get it out.
Unfortunately, there are two clips at the top, one around 4 cm from each end. To remove the cooler, you'll likely need to "raise" the shelf in the glove box above it a little bit.
Users browsing this forum: Majestic-12 [Bot] and 87 guests
