Fault code after having engine bay cleaned
Munnkey
Post by Munnkey » Sun Dec 08, 2019 4:39 pm
Hi All,
My EPC light came on after having the car valeted and engine bay cleaned on Friday.
Recovery truck came out and read the codes. Unfortunately I dont have full code print out.
He seemed to think it was the MAF sensor may have got wet.
I've attached his diagnosis and he said it would be ok to drive to a garage to fix. It seems to run ok but rev limiter is on.
Any other thoughts on what it could be or does this sound right?
Thx
Andy
AA_954
Re: Fault code after having engine bay cleaned
Post by AA_954 » Sun Dec 08, 2019 7:43 pm
Munnkey wrote:Hi All,
Thx
Andy
I’d also see if with the engine bay clean they hit a vacuum line and caused a leak affecting the operation of the intake runner on bank 1, any rough idling?
The EPC once on will indeed limit your revs to 7K until the issue is corrected.
Sent from my iPhone using Tapatalk Pro
Munnkey
Post by Munnkey » Sun Dec 08, 2019 7:49 pm
Thanks, will check the vacuum lines. It seems to run smoothly. Removed the MAF and it didnt appear wet so its a bit confusing
AA_954
Post by AA_954 » Sun Dec 08, 2019 7:52 pm
Munnkey wrote:Thanks, will check the vacuum lines. It seems to run smoothly. Removed the MAF and it didnt appear wet so its a bit confusing
Do you have obd11 or Vagcom to log the MAF readings?
Munnkey
Post by Munnkey » Sun Dec 08, 2019 10:57 pm
Unfortunately I dont have odb11 or Vagcom. I guess its maybe not enough information without full logs. Appreciate you taking the time to respond. I have a horrible feeling that fixing will involve little more than drying as its a big coincidence the day after an engine bay clean theres a sensor issue, but coincidences happen i guess. Will take it to a garage tomorrow to be sure.
GhiniRS4
Post by GhiniRS4 » Fri Jan 31, 2020 11:56 am
Need to be careful cleaning engine room.
I had twice been the problem. The first time was the spark plug then the second was a few days ago, rpm starts to go up and down on the first startup, the second startup is normal.
I still check with my technician, order the fuel pumps (have some of the leaks), pressure sensor, ignition coil, and flat contact.
Hope anything to be okay.
Munnkey
Post by Munnkey » Sun Feb 16, 2020 9:47 am
Turns out it was coincidence....manifold flaps were sticking. MRC deflap carbon clean and stage 2 map done. Very happy with the results!
Users browsing this forum: 666Lenine and 107 guests
