Flickering Left Bulb on B7 RS4
monkeychap
Post by monkeychap » Fri Dec 06, 2019 10:35 am
Hi All,
I've been advised this is most likely a controller problem rather than the bulb. I phoned Audi and gave them my reg number and they said the part I needed was 8P0907391. Before I go and buy a new one (ouch) I thought I'd better check:
1) is the controller the most likely cause ? It's only happening on left side. If I turn the light off and on again the problem goes away. Intermittent fault in other words
2) how do I check this is the right part ? Apparently it's for the non-adaptive xenon headlights. How do I know which type I've got ?
3) was going to fit it myself, but will be an evening job by the roadside in the dark. Is this feasible ?
Many Thanks !
Ian
Ian
B7 RS4 Avant
1984 911 Carrera (hotrod)
coffey555
Re: Flickering Left Bulb on B7 RS4
Post by coffey555 » Fri Dec 06, 2019 11:14 am
If the lights go up/down and then in and out during the self test at startup then you have adaptive lights. If they just go up and down then you have non-adaptive.
Could be a bulb on its way out, my one did this years ago and changing the bulbs fixed the problem. You are supposed to change Xenon bulbs every 3 years anyway as the light output drops off over time.
I left it to a garage to install, you need to move bits of the air intake to access the drivers side as well as having small hands!
Misano Red RS4 B7 Avant
monkeychap
Post by monkeychap » Fri Dec 06, 2019 12:09 pm
Thanks - Anyone recommend a bulb supplier ?
Ian
B7 RS4 Avant
coffey555
Post by coffey555 » Fri Dec 06, 2019 12:41 pm
I will be fitting Osram Nightbreakers shortly based on positive feedback from here.
Users browsing this forum: No registered users and 97 guests
