Clutch pedal Stuck
Gary(rs4)87
Clutch pedal Stuck
Post by Gary(rs4)87 » Wed Nov 20, 2019 2:54 pm
Quick question again: just noticed that when Sport mode ON clutch stuck on halfway way back. When using launch controls (just for sound, never used) then pedal stuck on halfway back.
Also my mechanic said he can hear some noise from the gearbox when he was under the car.
Thing is if I drive the car (sport button off) then everything is fine. But the rattle noise between 1000-1300 still there.
12th
Re: Clutch pedal Stuck
Post by 12th » Wed Nov 20, 2019 4:40 pm
Does it happen when you are using sport mode but driving gently, or only when you've been giving it the beans? If the latter, can you pull the pedal up with your foot and the car will the drive normally? If so, change clutch fluid to Dot 5.1 (higher boiling point). This is a common issue with the RS4, but this is cheap and solves it.
jamiej
Post by jamiej » Wed Nov 20, 2019 7:09 pm
Changing to Dot 5.1 may solve your issue. Topic has been discussed many many times before.
If not fluid, easiest fix (although not cheap) is a new clutch and flywheel assembly with a magic pipe from Robnic.
Sent from my ONEPLUS A6013 using Tapatalk
Current
'07 - Audi RS4 Avant Daytona Grey
'16 - BMW M135i F20 (LCI)
'53 - Land Rover Range Rover Vogue 4.4 V8
Gone
'02 Audi 8L A3 1.9 TDI (PD)
'03 Subaru Impreza WRX STI
'96 VW Golf VR6
'91 Toyota MR2 NA
'90 Peugeot 205 GTI 1.9
'90 VW Mk2 Golf GTI 8V
Gary(rs4)87
Post by Gary(rs4)87 » Sun Jun 28, 2020 9:52 am
jamiej wrote:Changing to Dot 5.1 may solve your issue. Topic has been discussed many many times before.
Pipe changed last week, now there is a vibration over 3000rpm
Users browsing this forum: EireRS6, Google [Bot], Google Adsense [Bot], rshales007 and 92 guests
