HELP NEEDED ON FRONT BRAKES
Frazz82
Post by Frazz82 » Tue Nov 05, 2019 9:14 pm
Please can someone help me with this. I ve gone to replace my front pads but the pin that holds the pads in is seized solid. Where is best to get a new one as i am going to destroy this one getting it out.
Scotia
Re: HELP NEEDED ON FRONT BRAKES
Post by Scotia » Tue Nov 05, 2019 9:45 pm
Hi not sure where you can get new pins from but if it’s just to get you moving and get the job done it’s only a couple of bolts at the rear of the Cali per 21 mm bolts I think and you can remove pads and Caliper together from the disc and remove pads from the caliper and get the job done , as long as the pins are not badly damaged should be safe in position as they are .
Hope this helps.
Ajc
Post by Ajc » Tue Nov 05, 2019 10:10 pm
I'm sure euro arse parts do a pin kit .
Cheers Al
Post by Shoppinit » Tue Nov 05, 2019 10:18 pm
^wot ‘e sed.
Matt58
Post by Matt58 » Tue Nov 05, 2019 11:51 pm
Brings back some horrible memories, I changed al discs and pads a few months back, my pins were seized solid, I sprayed loads of penatrating oil on and left to soak, tried several punches twisting, cutting and turning and still nothing, drilled them out in the end, 1.5 hour job turned into all day. Got pin/spring set from eBay
Frazz82
Post by Frazz82 » Tue Nov 05, 2019 11:55 pm
Cheers fella's. I removed the allen key bolts and changed the pads that way.
Thanks for your help.
Mɐʇʇ
Post by Mɐʇʇ » Tue Nov 05, 2019 11:59 pm
I'm just having mine completely remanufactured. It aint cheep, but I wanted a proper job.
I'll post a pic once they're back - they looked a lot like that when I sent them out.
ian_rs6avant
Post by ian_rs6avant » Thu Nov 07, 2019 12:50 pm
were you sent yours mate as i'm looking at sending mine!
Mɐʇʇ
Post by Mɐʇʇ » Fri Nov 08, 2019 1:01 am
Sent them to BCS - see my other post for pics.
Users browsing this forum: Google [Bot], rs4wagon, Shoppinit, srichards and 102 guests
