Makes sense, i was looking at Vmaxx times and theres usually a C6 in the top ten hitting 195-205mph, the best C7 was 178mph. Think doug was talking about low end acceration when we chated about C7 feeling quicker low down. Obviously 100mph, theres no comparison.don0301 wrote: ↑Sun Nov 03, 2019 11:37 amI was recently chatting with Doug at MRC, he told me the difference in top speed C6 v C7 was charge cooler v intercooler? ie the faster the C6 goes the more power it makes relatively? He said that's why the C6 makes 200mph so much easier and the C7 can't?
That's what I thought he meant anyway
Regarding the C6 gearbox, 6th is so tall you need approaching 800ps to be able to accelerate approaching 200mph I believe. When I had mine stage 2'd one of the options by MRC was to have the rev limit increased to achieve true 200mph. Mine changes gear 5th to 6th somewhere around 195mph on the clock....the car is VERY quick to 190mph ish but once in 6th at those speeds acceleration is much slower. I have made over 200mph true speed.
An upgrade to the stage2 C6 RS6
Re: An upgrade to the stage2 C6 RS6
With the MRC stage 2 map raising the rev limit to 7k rpm you hit 206mph indicated (200mph GPS) when it changes to 6th, but the second you hit 6th all the acceleration dies on it's arse regardless of having 700hp or 900+hp because the gearing is so tall at that point.
That's an interesting post. Firstly it's quite a good answer to my nerdy question about how high the engine can rev.
Second, it's a bit more complicated. The stock engine has a nearly flat torque curve from 2000 to 6250 rpm, and the power curve is nearly a straight line over that range, then peaks and drops sharply. I'd expect a stock engine to fall on it's face changing up to 6th flat out, because you lose a lot of power on the up-change with a peaky power curve.
Stage 2 engines are quite different, with torque hitting 1000+Nm from 3000 to 5000 rpm, then tapering downwards to the red line as the turbos trade pressure ratio for mass flow. So the power curve has a plateau rather than a peak, typically reaching 700+bhp from 5000 to 7000rpm. It's a sign that MRC have successfully wrung the neck of the turbos, and they're flowing all they can flow. It's a great formula for acceleration, as the average power is high over the range of engine speeds actually used. See Ian's link.
http://www.ianhenshall.com/audi58.jpg
However, if a stage 2 car changes up at 7000 rpm at 200mph, it will find itself at 5700rpm in 6th, right on peak power for most stage 2 tunes. In other words, the engine will produce MORE power at 200mph in 6th than it does in 5th, so the acceleration should actually increase on upshift. I've heard lots of people describe the same thing, but something doesn't add up, and I don't know what it is. It's not rolling resistance, so all I can think of is the transmission loss is higher in 6th, or the boost is limited, which is all unlikely.
Nick
Nick
You do talk sh1te....welwynnick wrote: ↑Sun Nov 10, 2019 11:00 amThat's an interesting post. Firstly it's quite a good answer to my nerdy question about how high the engine can rev.
Secondly, it doesn't add up. The stock engine has a nearly flat torque curve from 2000 to 6250 rpm, and the power curve is nearly a straight line over that range, then peaks and drops sharply. I'd expect a stock engine to fall on it's face changing up to 6th flat out.
Stage 2 engines are quite different, with torque hitting 1000+Nm from 3000 to 5000 rpm, then tapering downwards to the red line. This means the power curve has a broad plateau rather than a sharp peak, typically reaching 700+bhp from 5000 to 7000rpm. It's a sign the MRC have successfully wrung the neck of the turbos, and they're flowing all they can flow. It's a great formula for acceleration, as the average power is high over the range of engine speeds actually used. See Ian's link.
However, if a stage 2 car changes up to 6th at 200mph, while it's producing around 700bhp at 7000rpm, it will find itself at 5700rpm in 6th. This happens to be peak power revs for most stock turbo custom tunes. In other words, the engine will be generating MORE power at 200mph in 6th than it does in 5th. Therefore the acceleration should actually increase on upshift, rather than fall on it's face. So something, somewhere doesn't add up, and I don't know what it is. I've heard lots of people describe the same thing. All I can think of is that the transmission loss in 6th is much higher than 5th, but that seems an unlikely explanation.
Nick
It's because 6th is a much taller gear....
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
The map doesn't raise the rev limit generically if I recall, I was asked if I wanted it.IanH755 wrote: ↑Sat Nov 09, 2019 5:56 pmWith the MRC stage 2 map raising the rev limit to 7k rpm you hit 206mph indicated (200mph GPS) when it changes to 6th, but the second you hit 6th all the acceleration dies on it's arse regardless of having 700hp or 900+hp because the gearing is so tall at that point.
At those speeds, tyre tread depth, even what pressure will likely affect measured speed (speedo). As I said, mine changed at about 195 indicated when I did it. I had 213 indicated (203 gps) and still slowly increasing but had to shut off, that was with 770ps and 1100Nm.
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
I was hoping you'd say that.
When you disagree with someone, it's hard to accept they might be right, but I had actually begun to doubt myself.
But in one single post you have removed all of those doubts.
Thanks,
Nick
I went from a C6 to a C7. Did 60k in the C7 in two years with no major issues- as a ownership experience it was a fantastic car the perfect all round car. But I never stopped hankering after a C6, it has its flaws no doubt but it’s an epic car with a legendary engine. Recently had a sepang blue car drive past me and guess what I’m back looking for one in the classifieds. There is just something about them which I can’t explain - those who have owned one will know what I mean......
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Had mine over 5 years now, starting to look to replace as financially i can, but still love it. I'd love to keep it but practically not sure that's viable. Good luck with your search, must be getting harder now to find good ones.rtd wrote: ↑Fri Dec 06, 2019 7:08 amI went from a C6 to a C7. Did 60k in the C7 in two years with no major issues- as a ownership experience it was a fantastic car the perfect all round car. But I never stopped hankering after a C6, it has its flaws no doubt but it’s an epic car with a legendary engine. Recently had a sepang blue car drive past me and guess what I’m back looking for one in the classifieds. There is just something about them which I can’t explain - those who have owned one will know what I mean......
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
Audi seem to be keeping it quiet, but they've decided to go back to a pair of side mount air-air intercoolers on the C8 RS6.don0301 wrote: ↑Sun Nov 03, 2019 11:37 amI was recently chatting with Doug at MRC, he told me the difference in top speed C6 v C7 was charge cooler v intercooler? ie the faster the C6 goes the more power it makes relatively? He said that's why the C6 makes 200mph so much easier and the C7 can't?
That's what I thought he meant anyway![]()
Nick
when you did those observations on Stage ii car, assume it was tested in "S" (gearbox wise)?welwynnick wrote: ↑Sun Nov 10, 2019 11:00 amThat's an interesting post. Firstly it's quite a good answer to my nerdy question about how high the engine can rev.
Nick
2008 RS6 Avant (Monza Silver)
- H&R ARBs
- H&R ARBs
I'm an impostor mate, I haven't even bought my RS6 yet (though I've already bought VCDS and a 4 post lift to look after it). The observations are other people's - several owners said acceleration dies when you change up to sixth. My comments are just based on gear ratios and dyno charts. Yours is up for sale isn't it?
Nick
