Idling issue
neil_f
Re: Idling issue
Post by neil_f » Mon Oct 21, 2019 10:49 pm
ArthurPE wrote:
Mon Oct 21, 2019 10:27 pm
Beat me to it lol
140 g/sec at 7800 seems low
Take readings at intervals
3000, 4000, 5000, so on (20-22 g/sec per 1000 rpm)
If linear sensor is likely ok
Ok. Thanks for all the advice . Will do another run tomorrow and see what the readings are.
JamesBaby
Re: Idling issue
Post by JamesBaby » Tue Oct 22, 2019 7:21 am
[/quote]
Cheers. Noticed today that it smelt rich as well. Think I'll replace the maf and take it from there. Emailed opie as they don't list it on their site .[/quote]
Search by Bosch part number 0 280 218 187.
neil_f
Re: Idling issue
Post by neil_f » Tue Oct 22, 2019 3:26 pm
Well went to take it out today and car wouldn't start! Fault code of Starter Interlock Signal - short to ground . Reckon it could be a clutch switch? Cruise control has been working fine but for ages I've had to hold the starter button down when starting.
ArthurPE
Re: Idling issue
Post by ArthurPE » Wed Oct 23, 2019 8:22 pm
Yep imo clutch switch
Having to hold the starter is a symptom
MIDZ
Re: Idling issue
Post by MIDZ » Thu Oct 24, 2019 9:44 am
Another idea for the low idling issue, what about the PCV for returning breather fumes back to the air inlet. I'm sure I read somewhere on here a while back that it gives similar symptoms, maybe the diaphragm has perished or burst inside.
Almost like taking the engine filler cap off when the engine is idling
neil_f
Re: Idling issue
Post by neil_f » Fri Oct 25, 2019 4:45 pm
Replaced clutch switch today and still no joy!
neil_f
Re: Idling issue
Post by neil_f » Mon Oct 28, 2019 1:42 pm
Beat me to it lol
So took it a run today. Peak value of 147g/s at 8200rpm in 3rd gear. Readings at 1k rpm intervals start of at 20-22g/s but this starts to decrease above 5k rpm (18-19g/s) and drops lower still above 6k rpm (14g/s intervals )
ArthurPE
Re: Idling issue
Post by ArthurPE » Tue Oct 29, 2019 9:07 pm
imo the sensor seems ok
Something is choking it down >5000 rpm
neil_f
Re: Idling issue
Post by neil_f » Wed Oct 30, 2019 8:36 pm
Think maybe time for a carbon clean. Has never been done as far as I'm aware .
coffey555
Re: Idling issue
Post by coffey555 » Wed Oct 30, 2019 9:21 pm
I would put the airbox back to OEM assuming you still have all the parts?
Also, what engine map are you running, standard?
I noticed this the other day on the MRC website:
STAGE 2
A Stage 2 Map is custom to your car and performed on the dyno. Being normally aspirated every change to your car needs verified and proven on the dyno. Includes: Full throttle in all gears. VVT modifications. Linear throttle option in non sport mode. Secondary air injection disabled for running cold air feeds, no precats, racecats or no cats. Quiet mode start mode. Includes engine health check and dyno time.
"Secondary air injection disabled for running cold air feeds"
Not sure how this would effect a car with a standard map but strange how it is specifically mentioned on the MRC website.
Misano Red RS4 B7 Avant
neil_f
Re: Idling issue
Post by neil_f » Thu Oct 31, 2019 6:46 pm
Still have the parts but a pain to put back to standard as easiest with the bumper off again. The secondary air injection is still there and wired in . Only differnce is when the solenoid moves the flap the flap isn't attached to it anymore . My understanding is it only needs mapped if you want to remove all of it . Got it booked in for a dyno day on Sunday so will see what the outcome of that is .
neil_f
Re: Idling issue
Post by neil_f » Sun Nov 03, 2019 12:39 pm
So had it on the rollers today. Standard apart from centre res delete , panel filter and cold air feed. No history of carbon clean . Done 402bhp which is far more than I thought it would . Dyno seemed pretty accurate as power figures for other cars seemed about right ( within 10bhp of manufacturers figures).
