FIS Control
FIS Control
Has anyone installed FIS control (fis-control.de)?
I quite fancy the snake game
Re: FIS Control
I’ve thought about it, but u can get a p3 gauge that go’s in the air vent and I think that’s go more on it I could be wrong.
Re: FIS Control
I hear you, and some of them do look smart. However, I honestly don't think there's a day to day need (for me, at least) for all the detail you can get out of these. Sometimes boost is useful as an early heads up if something is in distress - but the rest of it I would immediately want logged via VCDS anyway.
However, snake FTW.
However, snake FTW.
Re: FIS Control
I'm half way through building a raspberry pi with a 4 inch touch screen too fit into an air vent , that when I figure it all out should display what I need and more , also little touches like being able too have programmed buttons on the display for ic fans , exhaust cut outs . Oh and I take your snake and raise it too pacman built in
Cheers Al
Re: FIS Control
I’m in for Pac-Man!!Ajc wrote:I'm half way through building a raspberry pi with a 4 inch touch screen too fit into an air vent , that when I figure it all out should display what I need and more , also little touches like being able too have programmed buttons on the display for ic fans , exhaust cut outs . Oh and I take your snake and raise it too pacman built in
Re: FIS Control
Interesting...
I've also got a little project going on for my RS4.
Using an arduino/ESP to get values wirelessly via the obd port and show them on the top 2 lines of the dis where the music info. normally is.
A few little tweaks with it and I'll be happy.
Mike
Sent from my PRA-LX1 using Tapatalk
Mike
Re: FIS Control
I have a couple of arduinos which I may end up using for the inputs from the harness for the sensors then over too the pi . I've not done much on mine for a while but need to pick the project up again at some point .mikep99 wrote: ↑Fri Oct 25, 2019 10:56 amInteresting...
Mike
Matt , I do like the dis upgrade , that was what kicked the while project off for me i think . They seem to be a fairly easy install to . As you say just for a boost reference at a glance its ideal for the job .
Cheers Al
Re: FIS Control
Does anyone know the difference between FIS full and FIS light? Light is cheaper, but can't find anything that explains the difference.
Re: FIS Control
If he’d released it 10 years ago he would have made a killing.
Re: FIS Control
From what I can tell, it looks like FIS full can have additional external sensors plugged into it and shown on the display.MattV8 wrote:Does anyone know the difference between FIS full and FIS light? Light is cheaper, but can't find anything that explains the difference.
Not sure if there's any other differences.
Mike
Re: FIS Control
For anyone doing arduino style hacking, look at the 'teensy' boards, they do a neat one (v3.2 I think) with dual can channels on it. This is very useful for taking one can stream in altering it and spitting out another modified network to a device. Signal to your dash in, then remove the CAN error messages and send that data out on the other can network to your dash (no MOT concerning warning lights)
It's a neater solution than an arduino and CAN shield IMHO.
Sent from my F8331 using Tapatalk
- anditsoundslikebells
Re: FIS Control
Maybe there is a better thread to bring back?
I'm thinking to install the FIS control unit.
All I'm really after is boost info and the current gear (at all times, including auto/sport mode)
I like the face the OEM display is used. There are some fancy colour displays but I think that detracts from the OEM look.
Does anyone know if it's feasible to somehow get the FIS display to just show the current gear? In a large format? Like the whole display?
https://m.youtube.com/watch?v=fTmMoa-X-zA
https://m.youtube.com/watch?v=YkxdWZVaYpg
https://www.drive2.ru/o/b/2998051/
I think this looks great:
RS6 C5 Avant 2002 Daytona Grey
TTH 620 - Wagner IC - OC.T 200cell&downpipes - DW400 pump - 034 TCU chip - FIS - B16 PSS9 - 034 control arms - H&R ARB - OZ Superturismo
Re: FIS Control
anditsoundslikebells wrote: ↑Sat Jan 28, 2023 8:28 pmMaybe there is a better thread to bring back?
This is exactly what I've been after! My dis is going pixalated now anyway so was going to replace but this seems much better!
Have you managed to find anymore information that's in english?
Re: FIS Control
Hmm. If there were a group buy of FIS Control, I could maybe be tempted, so I can sneak out to the garage and play snake in the car sometimes for a bit of peace and quiet.
