£1000 discs!?
Re: £1000 discs!?
You can ask this guys if they post it to you. 600 euros for a set
https://sidmotorsport.pl/en/hamulce/103 ... x34mm.html
440 euros for zimmermann ones
https://sidmotorsport.pl/en/hamulce/46- ... 34-mm.html
Re: £1000 discs!?
There was a big scandal with Reylands a few years back in the Clio scene when someone lifted a part number off a replacement two piece disc and it turned out to be a Euro car parts BMW X5 discs modified to fit their bells!Jayjay101 wrote: ↑Wed Oct 16, 2019 9:45 amim going with rayland next as it will work out cheaper in the long run as you can just change the discs and not the bells and always hear good things about there stuff(unless i can get ceramics cheap before that!) could also try RB racing a few guys on the Facebook group running them and have had no problems. taroxs also do a set and EBC have just started to do a set too.
Re: £1000 discs!?
Thats another good tip thanks.V!per wrote: ↑Wed Oct 16, 2019 12:44 pmYou can ask this guys if they post it to you. 600 euros for a set
I have found this kit in Germany https://www.lott.de/en/i1227208h5m3395t16628 which could be a good deal as it includes Vat, assuming the polish one does not.
Re: £1000 discs!?
They do, but the R8 disks are not side-specific. They use the same rotor on either side and I believe the right side runs "backward". Maximum cooling is probably less of an issue with the lighter, rear-engine setup. That said, I've been running R8 disks that I picked up cheap from someone upgrading their car. I have never had problems and even ran them on the track once with no issues.
Re: £1000 discs!?
EBC were asking for cars a few months back so they could work on a brake set up for the C5. I remember seeing pics of it in their workshop. Maybe worth giving them a call and seeing how far they have got with it ?
Re: £1000 discs!?
Nice thanks, will look into that also!
Re: £1000 discs!?
Have a look on autodoc.com think I got the Zimmerman disks for £180 each and shipping was very quick from germany
Re: £1000 discs!?
AP racing also do a disc and bell setup for the C5. I went with their C6 set (as I could get them cheaper and spaced the calipers out to suit (it's not ideal though) a caliper swap may be on the cards at some point.
Sent from my F5121 using Tapatalk
Re: £1000 discs!?
https://ebcbrakesdirect.com/automotive/ ... 2005/50603
Seems they got them for sale now..... Still not cheap though.... Floating 2 piece though....
Also no real world testing from anyone yet. I tend to always go by word of mouth.
Re: £1000 discs!?
Very similar price to Reyland for a similar looking product. Although they have listed them as fronts but it also shows 335mm diameter. If its £900 for some rears that is expensive!
I quite like the look of a pad and lines kit though. Has anyone tried the yellow stuff pads? For me it will be just for road use so do not need a track type pad.
Re: £1000 discs!?
I went for the Red Stuff ones - pretty much same braking as OEM but the compound is not producing so much brake dust
Re: £1000 discs!?
Great thanks, good info. Redstuff may be the ones then as its just a daily.
I have a query in with EBC to confirm what they have available but so far am not getting useful answers. Will update here if they come up with anything worth while.
Re: £1000 discs!?
also +1 for the r8 discs, they are also non directional makes them cheaper then our discs
Re: £1000 discs!?
The C6 are non directional, too.
Users browsing this forum: Google [Bot], skyegtb and 92 guests
